Vijaysud
  • 6
Message 1 of 11
url not opening on Virgin home broadband wifi
Hi, so there is a URL which does not open up on Virgin Wifi. It is www.adib.ae - it is a bank's website which opens fine on 4G/cellular and even on Virgin Media public wifi.
on the home wifi it gives the error as
This site can't be reached
adib.ae's server IP address could not be found.
try:
checking the connection
Err_name_not_resolved
The bank's App also does not work on virgin's home wifi but works everywhere else, which is really frustrating.
  • 24.02K
  • 2.54K
  • 4.36K
Message 2 of 11
Re: url not opening on Virgin home broadband wifi
Works just fine for me here ....
Vijaysud
  • 6
Message 3 of 11
Hi John, well that's my point. The error is because of some setting on my home wifi which is causing this particular website to not open. It is opening everywhere else.
sophist
  • 2.55K
  • 420
  • 683
Message 4 of 11
try changing the DNS servers on teh device you're trying to connect with to 8.8.8.8 / 8.8.4.4
details on how to do this (for various different operating systems) can be found here
Vijaysud
  • 6
Message 5 of 11
Thank you @sophist; this worked amazingly on both laptop and phone. But I wanted to check, there should be a solution to resolve the issue for all devices i.e. making some kind of change on the router settings of Virgin, correct? Would you be able to guide on that.
sophist
  • 2.55K
  • 420
  • 683
Message 6 of 11
Unfortunately, you can’t change the dns settings on the VM hub. You’ll have to set this manually on any device you want to access that site from… if you had your own 3rd party router you’d be able to configure it to setup whatever dns servers you liked…
is this a problem that has started recently? If so, you may find that it resolves itself in a few days… could just be some caching on vm’s dns servers that’s not working properly but will sort itself out when the cache expires.. if it’s been a problem for a while then it might be something different and will need some more investigation
Vijaysud
  • 6
Message 7 of 11
Well, we recently got VM connection, so really not sure if we ever opened the bank website after the connection but only after thorough check with the bank I reached out here. But I am surprised that VM twchnical support team is unavailable for almost past 10 days and it's just impossible to pass the bot over phone or chat! Sigh!
Vijaysud
  • 6
Message 8 of 11
Dear Virgin Media team,
i need help from your technical team because the mobile application of ADIB bank is still NOT working on wifi. Adding the dns server made the website work but not the application.
The app works completely fine elsewhere except home wifi 🤔😵💫 #puzzled
The bank also checked all possibilities at their end.
Please contact me urgently.
PS: if anybody knows how to resolve then please help, in lieu I am willing to call/chat online with VM's Bot and waste 5 minutes of my life on it! (Sic)
g0akc
  • 999
  • 92
  • 197
Well-informed
Message 9 of 11
The app is working for me (I cannot test fully as I don't have an account with that bank).
What device are you running the app on?
Does that device have the non VM DNS (Google DNS) set as advised previously?
Do you get any error message?
To look further I would need a trace - I don't suppose you can capture a trace?
Can you get any support from the bank?
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
g0akc
  • 999
  • 92
  • 197
Well-informed
Message 10 of 11
And, since VM will likely ask you anyway - try rebooting (power off/on) the Hub - and if that does not work try a factory reset using the pinhole button for a minute.
