If you get disconnections on ethernet cable connected devices - do this.
__________________________________________________________
Post up your Hub/network connection details and someone will check to see if there is a problem there. In your browser’s URL box type in
http://192.168.0.1 (or
http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. Dont log in just click on the “router status” icon/text at bottom-middle (Hub3) of the Login page.
Then Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs page. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
