Talbot_Sunbeam
Message 1 of 7
unstable connection
I wonder if anyone can can offer me any advice.
I have always been pretty satisfied as a VM customer, since long before they called that, but I have been struggling with an intermittent connection and packet loss issues for 3 or 4 years now, despite several engineer visits and calls to support it never goes away and sometimes gets worse.
I use my V3 box in modem mode.
*My apologies I have had to remove the formatting due as I was exceeding the character limit.
Router status
Refresh data
Cable Modem Status
Item
Status
Comments
203000000
Locked
Ranged Upstream Channel (Hz)
43100000
Locked
Provisioning State
Online
Refresh data
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
203000000
6.1
40
256 qam
9
2
139000000
5.3
38
256 qam
1
3
147000000
5.6
40
256 qam
2
4
155000000
5.6
40
256 qam
3
5
163000000
5.9
40
256 qam
4
6
171000000
6.1
40
256 qam
5
7
179000000
6.3
40
256 qam
6
8
187000000
6.3
40
256 qam
7
9
195000000
6
40
256 qam
8
10
211000000
6.5
40
256 qam
10
11
219000000
6.9
40
256 qam
11
12
227000000
7
40
256 qam
12
13
235000000
7
40
256 qam
13
14
243000000
7
40
256 qam
14
15
251000000
6.8
40
256 qam
15
16
259000000
7.1
40
256 qam
16
17
267000000
7
40
256 qam
17
18
275000000
7
40
256 qam
18
19
283000000
7.4
40
256 qam
19
20
291000000
7.1
40
256 qam
20
21
299000000
7.8
38
256 qam
21
22
307000000
7
38
256 qam
22
23
315000000
7.4
40
256 qam
23
24
323000000
7.5
40
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.9
1797286
647526
2
Locked
38.9
2126693124
5358431
3
Locked
40.3
1672493817
3695372
4
Locked
40.9
969494650
1560730
5
Locked
40.9
1669144
1016720
6
Locked
40.3
1677224
1000335
7
Locked
40.3
1689083
966035
8
Locked
40.3
1666397
621149
9
Locked
40.9
1628546
1006025
10
Locked
40.3
1691128
181223
11
Locked
40.3
1751978
539029
12
Locked
40.3
1591576
921336
13
Locked
40.9
1670071
650900
14
Locked
40.3
1697547
339207
15
Locked
40.3
1758301
721124
16
Locked
40.3
1792479
184277
17
Locked
40.3
1721500
492825
18
Locked
40.3
1259167
45108
19
Locked
40.3
549363
2297
20
Locked
40.3
11432
654
21
Locked
38.9
1723802
571056
22
Locked
38.9
1551696
933786
23
Locked
40.3
1590321
883871
24
Locked
40.3
1803425
299132
come back!
Sign in to view or modify your Hub 3.0 settings.
Password
Router status
Status
Downstream
Upstream
Configuration
Refresh data
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
43100000
43.3
5120
64 qam
2
2
23600000
41.3
5120
64 qam
5
3
30100000
41.8
5120
64 qam
4
4
36600000
42.3
5120
64 qam
3
5
49600000
43.8
5120
64 qam
1
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
2
0
2
ATDMA
0
0
10
0
3
ATDMA
0
0
2
0
4
ATDMA
0
0
5
0
5
ATDMA
0
0
6
0
Welcome back!
Password
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
87dsfd;kfoA,.iyewrkldJKDHSUBs
SFID
4546
Max Traffic Rate
402500089
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
4545
Max Traffic Rate
38500089
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
BestEffort
Refresh data
Time
Priority
Description
06/02/2023 13:56:45
critical
06/02/2023 13:56:44
critical
Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/02/2023 13:56:5
critical
06/02/2023 13:56:5
critical
06/02/2023 13:53:45
critical
06/02/2023 13:53:45
critical
06/02/2023 13:43:46
critical
06/02/2023 13:43:46
critical
06/02/2023 13:43:26
critical
06/02/2023 13:43:26
critical
06/02/2023 13:42:46
critical
06/02/2023 13:42:46
critical
06/02/2023 13:41:46
critical
06/02/2023 13:41:46
critical
06/02/2023 13:39:46
critical
06/02/2023 13:39:46
critical
05/02/2023 23:52:8
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2023 23:52:8
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2023 23:52:8
Warning!
05/02/2023 23:05:54
critical
Anonymous
Not applicable
Message 2 of 7
Re: unstable connection
Not the easiest post to read tbh but looks like lots of post RS errors and timeouts.
Make sure all cables and connections are tight and in good condition and try a 30 second pinhole reset of the hub.
Also check for local faults on 0800 561 0061.
  • 13.85K
  • 1.07K
  • 2.81K
Message 3 of 7
If you post the stats as separate entries they will be accepted.
Too many errors, but the figures are accumulative since the hub was last power cycled. So please turn off your hub for a short period, this will reset the counters, then post a new full set of stats after about two hours. This will indicate the current line status.
Travis_M
  • 4.58K
  • 169
  • 335
Message 4 of 7
Hi @Talbot_Sunbeam
Thanks for posting on our community forum and a warm welcome with this being your first post here, sorry to hear about the issue with your broadband.
The issue is being caused by an SNR [Signal Noise Ratio] outage in your area, the team are working hard to find the fault along the network and have this resolved as soon as possible for you. The estimated fix date is currently 14 Feb at 16:55 - you may notice the connection slow down / drop out regularly whilst this is ongoing. My apologies for the inconvenience and we hope to have this resolved soon
Travis_M
Talbot_Sunbeam
Message 5 of 7
Thank you, for your responses. I will monitor again after the 14th. As I have experienced this issue for 3 or 4 years I don't hold out much hope of a proper solution as this is far from first time I have been told a fix is underway.
I have looked at the stats screens a lot over the last year or so, what was posted before is about 2-4 weeks of uptime and was worse than usual. 2 hrs is likely to look close to perfect (depending of what 2 hrs) 2 days will always have hundreds of post RS errors and on worse days its 10's of thousands.
My box was powered off and on when I made the original post so below is around 48 hrs.
Welcome back!
Password
11550000005.540256 qam3
2139000000538256 qam1
31470000005.538256 qam2
41630000005.640256 qam4
51710000005.940256 qam5
6179000000640256 qam6
7187000000640256 qam7
81950000005.840256 qam8
9203000000640256 qam9
102110000006.340256 qam10
112190000006.640256 qam11
122270000006.840256 qam12
132350000006.640256 qam13
142430000006.640256 qam14
152510000006.540256 qam15
16259000000740256 qam16
172670000006.940256 qam17
182750000006.940256 qam18
19283000000740256 qam19
202910000006.940256 qam20
212990000007.540256 qam21
223070000006.940256 qam22
233150000007.140256 qam23
243230000007.340256 qam24
1Locked40.31402242
2Locked38.91461277
3Locked38.91303496
4Locked40.3152880
5Locked40.3105047
6Locked40.337715
7Locked40.31110
8Locked40.91320
9Locked40.32000
10Locked40.31360
11Locked40.31380
12Locked40.31080
13Locked40.3590
14Locked40.31890
15Locked40.33390
16Locked40.93650
17Locked40.94200
18Locked40.34260
19Locked40.32320
20Locked40.31490
21Locked40.31040
22Locked40.31040
23Locked40.31220
24Locked40.3650
Welcome back!
Password
Router status
    Status
    Downstream
    Upstream
    Configuration
Refresh data
1 43100000 42.3 5120 64 qam 2
2 23600000 41.3 5120 64 qam 5
3 30100000 41.8 5120 64 qam 4
4 36600000 42.3 5120 64 qam 3
5 49600000 43.8 5120 64 qam 1
1 ATDMA 0 0 0 0
2 ATDMA 0 0 2 0
3 ATDMA 0 0 3 0
4 ATDMA 0 0 0 0
5 ATDMA 0 0 0 0
Talbot_Sunbeam
Message 6 of 7
The snapshot below is 23hrs from 20:00 on the 16th to around 19:00 on the 17th. I am still having some issues.
1155000000538256 qam3
21390000004.438256 qam1
31470000004.838256 qam2
41630000005.140256 qam4
51710000005.440256 qam5
61790000005.440256 qam6
71870000005.340256 qam7
81950000005.140256 qam8
92030000005.440256 qam9
102110000005.640256 qam10
112190000006.338256 qam11
122270000006.338256 qam12
132350000006.140256 qam13
14243000000640256 qam14
15251000000640256 qam15
162590000006.540256 qam16
172670000006.540256 qam17
182750000006.440256 qam18
192830000006.540256 qam19
202910000006.440256 qam20
21299000000738256 qam21
223070000006.540256 qam22
233150000006.840256 qam23
243230000006.940256 qam24
1Locked38.978163119
2Locked38.92067519933
3Locked38.61266715497
4Locked40.371723798
5Locked40.359973785
6Locked40.345463753
7Locked40.335283727
8Locked40.933534196
9Locked40.934833259
10Locked40.330193464
11Locked38.928613542
12Locked38.927633323
13Locked40.323163238
14Locked40.319633087
15Locked40.918203058
16Locked40.316042727
17Locked40.313672773
18Locked40.312932581
19Locked40.311132208
20Locked40.39582438
21Locked38.910332340
22Locked40.39852422
23Locked40.39542182
24Locked40.3826
1828
14310000043.5512032 qam2
22360000041.5512032 qam5
33010000042512032 qam4
43660000043512032 qam3
54960000043.8512032 qam1
1ATDMA0010
2ATDMA0020
3ATDMA0010
4ATDMA0000
5ATDMA0010
Robert_P
  • 5.5K
  • 251
  • 475
Message 7 of 7
Hello Talbot_Sunbeam
We're sorry to hear of the connection issues impacting your broadband connection, we appreciate the frustration this can cause and you taking the time to raise this via the forums.
From checking the connection and equipment we can confirm there is currently an area SNR issue under reference F010406516, this has and estimated fix date and time of today (20th February 2023) at 4.55pm. Hopefully once this issue is resolved you should see an improvement in the service.
Let us know.
Rob
