two networks from my my hub 3?
I can see two networks on my wifi settings page on my phone.  One is the hub VM****** the other says simply virgin Media.  I have no diea wha tthe second onerefers to as I can't seem to sign into it.
kevin
  • 15.84K
  • 1.79K
  • 3.68K
Re: two networks from my my hub 3?
All hubs additionally transmit a public WiFi hotspot. This is totally separate from your own network connection & does not affect your service in any way.
If you install the Virgin Media Connect app, it will give you access to these hotspots anywhere.
Virgin BB TV Landline. Freeview/Freesat HD, Virgin Mobile, Tesco Mobile. Cable customer since 1993
  • 6.02K
  • 1.14K
  • 1.6K
Hello
The Virginmedia network is a public access point you can opt out of it by logging into your virginmedia account at https://my.virginmedia.com/my-profile/view when logged in scroll down the page and there is section "Virgin Media WiFi" where it will  allow you to Opt Out and the click confirm.
Regards Mike
