So for months now my “not so superhub”
has been playing up.
issue as follows.
wifi dropout
webui slow to load or fails to load via lan or wifi.
port forwarding fails to work
NAT issues.
It’s borderline useless.
when i need to login in to remote reboot it takes so long to load the main page and then it kicks me out, i try to log back in and then tells me i can’t login as someone else is already logged in.
Iv had the unit for a few years now and the device is rubbish. wifi doesn’t even go through one floor. either.
can a member of the team arrange an upgrade to the newer hubs? il send this junk back then.
what iv tried
reset to defaults
turning it off and on
leaving it off for 10 mins etc
thanks.
