suggestions for 8 port 1gb wifi router for hub 3
winemart
As subject, just had a hub 3 fitted and old wap and router are 10/100. Engineer also suggested deco.
Do i need a switch etc?
1 ACCEPTED SOLUTION
Accepted Solutions
Legend
If you are intending a network like this ...
Hub 3 (Modem mode) >>>>> DECO (Router mode)  >>>>> 8 Port Gigabit switch >>>>> TV/PCs/Printer/AP etc
... below is an example of a 8 Port Switch to consider ...
https://www.tp-link.com/uk/business-networking/unmanaged-switch/tl-sf1008d/
3 REPLIES 3
Legend
Many thanks.
Bear in mind that link is only a 10/100 Hub, not gigabit.
