sloww non existent speed
Hi all i have been having the same problem for 3 weeks. Very slow non existent speeds with a wired connection and wifi, I was told to post here as the agents have no clue what they are talking about.
I have the Hub3 with a 100mbps tariff
I am so angry right now i am told the same thing all the time, i even went and bought new cables which set me back over £20 and that didn't do a thing. I took my laptop to a friends house only a few doors away on the same tariff as i am and it was fine, i was getting 100mbps via wired and over 70mbps on wifi. So it isn't my laptop or cables. went home tried again and i am not even getting 20mbps on a wired connection and only 25mbps on wifi. Still no call back as previous agree with another agent on Tuesday morning. I have tried calling a few times and cannot get through after 1hr.30min on hold.
  • Like
  • 12.14K
  • 943
  • 1.56K
Re: sloww non existent speed
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Mike Robinson
After almost 4 weeks of the same problem and Virgin saying there is nothing wrong I finally managed to get an engineer out and he found a fault with the box, It is working fine now.
  • 4.65K
  • 184
  • 252
Hi paul0001,
Thank you for your post and welcome to the community.
I'm very sorry to hear about the broadband issue you had. I'm glad to hear that has been resolved for you now.
^Martin
