  • 56
Message 1 of 8
slow wifi
hi all after some help my wifi is really slow 55mbps been like this few few weeks now and now keeps dropping out for like 5 mins then comes back on has done this several times today check everything and says no faults anyone help thanks
  • 24.7K
  • 1.42K
  • 3.14K
Message 2 of 8
Re: slow wifi
What are your wired speeds like?
  • 56
Message 3 of 8
Re: slow wifi
i don't have wired speed as im on laptop that doesn't have a ethernet port in it i have had a technician out a few months ago about the speed he changed the hub and the speed was the same and basically said its the best speeds your going to get i think he just fobed me off as he could figure out the issue
  • 31.37K
  • 1.63K
  • 5.49K
Message 4 of 8
Re: slow wifi
wifi has no minimum speed guarantee. you need to prove its not the wireless by testing with a wired connection.
VM won't be able to do anything about wireless.
  • 56
Message 5 of 8
Re: slow wifi
ok but what can i do about it dropping out all the time
  • 24.7K
  • 1.42K
  • 3.14K
Message 6 of 8
Re: slow wifi
No he didn’t fob you off. He proved the point given above.
  • 24.7K
  • 1.42K
  • 3.14K
Message 7 of 8
Re: slow wifi
Put the hub into modem mode and get your own better router or mesh system.
Or run a wired access point or two.
  • 56
Message 8 of 8
Re: slow wifi
ok what's a mess system never herd of one of them im not very technical
