slow speed while using modem mode
i have just moved my superhub 3 in to modem and i have had drop in speed
Standard specification compliant: DOCSIS 3.0
Hardware version: 10
Software version: 9.1.1811.401
Cable MAC address: **:**:**:**:**:**
Cable modem serial number: AA1P73631745
System up time: 0 days 0h:30m:9s
Network access: Allowed
this is connected connected to a netgear RX500 with multi-devices connect to it via both ethernet and wifi.
 PING ms  24
 DOWNLOAD Mbps  73.94   UPLOAD Mbps  36.96
the upload speed is as advertised, i have rebooted the superhub
i have just directly connect to superhub, and the speed for download dropped down to 1.96 Mbps
Tags (3)
  • 926
  • 68
  • 127
Well-informed
Re: slow speed while using modem mode
If you run your net gear in router mode is the speed the same or better?
the Netgear is in router mode, the speed has only dropped since i changed the VM superhub
strange, now the speed is now back to normal speed,
