on 31-08-2023 21:26
how do i get signal boosters cant find anywhere to order them on the app or on the website any help would be appricated
on 01-09-2023 10:26
What do you mean by 'signal boosters'?
Is this for the WiFi?
You should be able to use the VM Connect app to 'scan' or 'survey' your property and, if speeds are poor to some rooms, order PODs
Have a look at the WiFi max page;
Be aware that unless you are on the fastest packages there will be a rental fee of £8/month. You can get an O2 mobile SIM, if you don't already have one, instead and qualify through Volt.
A good alternative is to get your own WiFi kit such as a Mesh system.
on 03-09-2023 10:39
Hey dyannweekss1,
Welcome to the community and thanks for taking the time to post here on the forums.
I’m sorry to hear of the issues that you’re having trying to order WiFi pods to help improve your WiFi signal. Have you tried to use the Connect App as advised by g0akc to scan for issues and order a WiFi pod?
Kind Regards,
Steven_L
