Chrisevanz
  • 14
Message 1 of 18
remote access hub 3
Right how do you use the hub3 remote access. I know with my old hub when I logged into the router it gave me a http:// address then I could log in using that. With the hub3 it gives me a port address. So can some one explain how I remote access my hub3 using my phone when in not at home.
DJ_Shadow1966
  • 6.86K
  • 1.31K
  • 1.9K
Message 2 of 18
Re: remote access hub 3
Hello
That would be http://address:port
Mike
Chrisevanz
  • 14
Message 3 of 18
Thanks for reply but what would be the http//:address please
chenks
  • 3.65K
  • 203
  • 617
Community elder
Message 4 of 18
whatever your WAN IP address happens to be
Chrisevanz
  • 14
Message 5 of 18
Thanks again for reply but where do I find my wan ip thanks
Chrisevanz
  • 14
Message 6 of 18
Ok I have found my wan ip but google couldn’t open it or safari have I got to do something with port forwarding to allow page to open thanks in advance it was so much easier on the hub 2
  • 15.91K
  • 687
  • 1.56K
Message 7 of 18
Use Google
Chrisevanz
  • 14
Message 8 of 18
Thanks but that means nothing for me don’t know what to do there thanks for your patience as I might be sounding thick 😒 I’m obviously doing something wrong
chenks
  • 3.65K
  • 203
  • 617
Community elder
Message 9 of 18
i suppose the question would be is this.
if this part is a struggle for you why are you even attempting to do this?
for what purpose do you need to have remote admin access to your hub?
Chrisevanz
  • 14
Message 10 of 18
so that I can control my hub when I’m away from the home
