red light on virgin media hub
mrmildew_
Hi I have the same issue with my hub. I've tried everything that was said above but the red light is still on! This has been happening for the past 3 days, the internet is still working but I do not want to leave it any longer as I need my internet to be available. Please can you send me a new hub - the current one is 3 years old thank you!
5 REPLIES 5
Yes it will probably need replacing, but it must be done by a technician.
Megan_L
Hi mrmildew_,
Thanks for using the Community Forums to get this issue with your Hub looked into, I am sorry if this has been causing some frustration 😥 I would be more than happy to look into this for you!
Could you tell us whether you've tried to do a Pin-Hole reset please?
If you have and it is still showing the red light, let us know and we can help further!
Megan_L
Hi Megan_L
I have tried the pin-hole reset and powering off several times
The red light will not go away!
Hi Megen_L
Another day gone by and still the red light persists
Have you a resolution for me please?
Hello mrmildew_
Thanks for replying.
I'd like to take a look into this for you and arrange for the hub to be swapped.
If you can check your logo at the  top right of your screen that would be great.
Gareth_L
