  • 17
power levels
Could somebody let me know what the power level maximum / minimum levels should be for upstream and downstream please.  I suffer from frequent broadband dropouts - I think because the power levels keep fluctuating,  but I want to be able to prove it.  I've just had a new hub delivered because the old one kept resetting to factory settings  after each drop out, however whilst the new hub retains it settings, it still appears to cut out and reboot several times a day
  • 3.68K
  • 307
  • 1.07K
Community elder
Re: power levels
Downstream:  -6 dBmV to +10 dBmV
SNR:  Should be greater than 34.5dB
Upstream:  +31 to +51 dBmV
Some Pre-RS errors are to be expected but there should be no Post-RS errors on a healthy connection.
********* SuperHub 2ac - Asus rt-ac68u Router - Vivid 100Mbps **********
Electron
  • 854
  • 130
  • 425
Re: power levels
Actually to be safe, you want the upstream to be stable as a bit less that; that say high 40's dbmV. In hot weather the impedance of the cables will rise and push the power levels up as well. At 51 the cable modem should reboot itself to try and renegotiate a better connection - which might be what you are seeing.
