post RS errors
Brezzz
Was wondering if virgin staff could take a look at my connection please. I seem to be getting a lot of packet loss and latency related issues. Noticed that my post RS error count is also quite high. My BQM doesn't look too bad from what I can see but my connection is really suffering. My power levels seem to be on the high side, although are just within limits. The last virgin tech put a 3db forward path on to help with upstream levels around 6 months ago but I have since upgraded to hub 5 and 1gbps. I have checked all internal cabling and performed factory reset on the hub. I'll post my stats below as well for reference.
Many Thanks
12270000008.138QAM 25612
21950000008.638QAM 2568
32030000008.138QAM 2569
42110000008.738QAM 25610
52190000008.638QAM 25611
62350000008.638QAM 25613
72430000007.938QAM 25614
82510000008.338QAM 25615
92590000008.338QAM 25616
102670000008.238QAM 25617
112750000009.138QAM 25618
122830000008.738QAM 25619
132910000009.739QAM 25620
142990000009.539QAM 25621
153070000009.239QAM 25622
163150000009.839QAM 25623
17323000000939QAM 25624
183310000009.839QAM 25625
193390000009.639QAM 25626
203470000009.439QAM 25627
213550000001039QAM 25628
223630000009.139QAM 25629
233710000009.839QAM 25630
243790000009.639QAM 25631
253870000009.539QAM 25632
2639500000010.439QAM 25633
274030000009.639QAM 25634
2841100000010.239QAM 25635
294190000009.339QAM 25636
305230000009.539QAM 25637
3153100000010.639QAM 25638
1Locked3810067521
2Locked38117172005
3Locked38103331565
4Locked3897671127
5Locked389794784
6Locked3810059324
7Locked389885133
8Locked38855714
9Locked38643610
10Locked3842460
11Locked3826230
12Locked3817560
13Locked398510
14Locked393340
15Locked39550
16Locked39110
17Locked39100
18Locked3920
19Locked3900
20Locked3920
21Locked3900
22Locked3910
23Locked3920
24Locked3930
25Locked3920
26Locked3920
27Locked3920
28Locked3920
29Locked3910
30Locked3920
31Locked3930
1 REPLY 1
Post up the Upstream data and network logs - also a link to your "share live" BQM.
Also have the PostRS errors increased since what you posted above ?
