PeteT41
  • 9
poor wifi signal strength
Just installed a replacement Hub3. Still not got much better broadcast strength.  I get 250meg if I sit on the router and 2 rooms away its down to 5meg.  I had a booster pod installed.  I have turned it off and on as suggested but it won't connect.  The Connect app says I have poor reception - dont need an app to tell me that.  I live in a 4 story terrace so its not a big house.  I have an additional booster pod on order I- it is only 2 week late being delivered.  Cant get through on the phone.  Time to switch to BT I feel
Tags (4)
Christy_D
  • 1.08K
  • 149
  • 167
Re: poor wifi signal strength
Good Evening
Have you ran any troubleshooting on the WiFi pods to ensure that they've been set up correctly?
Heres the page if you haven't already had a look on it. https://www.virginmedia.com/help/virgin-media-booster-and-pods-troubleshooting/virgin-media-pod-trou...
Christy
Ernie_C
  • 18.18K
  • 1.98K
  • 4.41K
The new Hub and WiFi Pod won’t be correctly associated on your account.
It really is time that the process for replacing a Hub includes a check to see if the customer has WiFi Pods.
Tags (1)
PeteT41
  • 9
Yes.  done that twice.  seems the first response from Virgin is always to just reboot, not very helpful and doesn't solve this.  I see other posts that connections to a replacement hub is a common problem
PeteT41
  • 9
thanks.  is there a fix. just spoken with help desk, they say just turn off and on!
PeteT41
  • 9
Ernie, they spent ages rebooting my POD with the new HUB, I now have 2 PODs in my house and still poor coverage for wifi.  I live in a 4 bed terrace, not a mansion.  Surely the strength should be better?
