  • 8
Message 1 of 11
poor speed
Hi Guys, as much as we have a broadband speed in excess of 100mbps all our devices, both apple and android, keep switching to 4g due to 'poor broadband speed or quality' This has gone on for months now. Sometime it drops off completely over 20 times a day. Tried all the fixes recommended and installed access points and hard wired to devices. HELP!
  • 7.11K
  • 527
  • 921
Legend
Message 2 of 11
Re: poor speed
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 8
Message 3 of 11
Re: poor speed
  • 8
Message 4 of 11
Re: poor speed
Do
13310000001438256 qam25
220300000013.538256 qam9
321100000013.338256 qam10
421900000013.138256 qam11
52270000001338256 qam12
623500000012.538256 qam13
724300000012.538256 qam14
825100000012.338256 qam15
925900000012.138256 qam16
1026700000012.138256 qam17
1127500000012.538256 qam18
1228300000012.840256 qam19
1329100000012.838256 qam20
1429900000012.938256 qam21
153070000001338256 qam22
1631500000013.838256 qam23
1732300000013.938256 qam24
183390000001438256 qam26
193470000001438256 qam27
2035500000013.838256 qam28
213630000001438256 qam29
2237100000013.538256 qam30
2337900000013.538256 qam31
2438700000013.540256 qam32
1Locked38.9180
2Locked38.6330
3Locked38.9300
4Locked38.9320
5Locked38.6390
6Locked38.6240
7Locked38.6350
8Locked38.9400
9Locked38.9260
10Locked38.9310
11Locked38.9220
12Locked40.3200
13Locked38.9170
14Locked38.9390
15Locked38.6260
16Locked38.9270
17Locked38.9260
18Locked38.9300
19Locked38.9260
20Locked38.9210
21Locked38.62765
22Locked38.6230
23Locked38.9450
24Locked40.92725
wnstream
  • 8
Message 5 of 11
Re: poor speed
1394000004.125512064 qam2
2258000004.075512064 qam4
3326000004.125512064 qam3
4461999934.275512064 qam1
3ATDMA0000
4ATDMA0000
  • 8
Message 6 of 11
Re: poor speed
TimePriorityDescription01/09/2020 06:32:6noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsl10016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;01/09/2020 06:32:6ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;31/08/2020 15:47:0ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;31/08/2020 02:33:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;31/08/2020 01:01:57ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;27/08/2020 09:43:43criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/08/2020 12:51:44noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsl10016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/08/2020 12:51:44ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;26/08/2020 02:43:9ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;25/08/2020 22:28:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;25/08/2020 16:34:37ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;23/08/2020 16:15:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;22/08/2020 14:12:5noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsl10016u-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;22/08/2020 14:12:5ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;21/08/2020 07:22:57ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;20/08/2020 16:18:1criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;20/08/2020 14:52:26Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;20/08/2020 00:38:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;18/08/2020 16:12:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;17/08/2020 17:32:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 4.86K
  • 895
  • 1.29K
Message 7 of 11
Re: poor speed
Hello
On your downstream your power levels are well above the maximum of +10 you are going to need an engineer to resolve.
I have escalated to the VM forum team, somebody will be along in this thread to resolve it for you.
Regards Mike
  • 8
Message 8 of 11
Re: poor speed
Thanks Mike, much appreciated.
Sean
  • 2.76K
  • 209
  • 276
Message 9 of 11
Re: poor speed
Hey seanthesheep14,
I have been able to locate your account and agree with the diagnosis from DJ_Shadow1966 about your downstream power levels.
I have booked an engineer visit for you for tomorrow morning, you can find more details of your appointment by logging into your online account then clicking  > My Profile > Order Tracking.
Steven_L
  • 8
Message 10 of 11
Re: poor speed
HI Guys
Still having problems especially with mobile devices. They keep switching to 4G as internet is poor quality. Did a quick speed test and it was 5.12mbps! not good on a 100mbps contract. let me know if any more info is required.
Thanks in advance
sean
