tatterz94
  • 5
Message 1 of 9
paying for 200mbps, getting less than 30mbps regularly!
I have been on the 200 mbps plan for some time now and it started out great but within a month I'm getting massive drops in speed and downloading anything takes forever as every speed test I've done gives me a reading of 20 or lower, HELP!
I've reset my hub and it doesn't seem to help!
gary_dexter
  • 30.55K
  • 1.89K
  • 4.06K
Message 2 of 9
Re: paying for 200mbps, getting less than 30mbps regularly!
On a wired connection?
tatterz94
  • 5
Message 3 of 9
WiFi connection!
I don't want to use wired connections as I'd need a long cable!
gary_dexter
  • 30.55K
  • 1.89K
  • 4.06K
Message 4 of 9
@tatterz94 wrote:
WiFi connection!
Then you have no way of accurately measuring speeds then.
Wifi speeds and connectivity aren’t guaranteed so you have to test with a wired device.
tatterz94
  • 5
Message 5 of 9
fair point but I've measured on two separate WiFi devices (phone and playstation) and they both give similarly low readings!
gary_dexter
  • 30.55K
  • 1.89K
  • 4.06K
Message 6 of 9
OK. But that’s still not on a wired connection.
Hayley_S
  • 545
  • 20
  • 46
Message 7 of 9
Hello @tatterz94,
Welcome back to the community page, thank you for posting on here.
I am sorry to see you are not happy with your current WiFi speeds, I was able to locate your account using your forums details. I can not see any known issues with your Hub.
What speeds are you currently getting on your WiFi? Please can you check by clicking here.
Also, are you able to use your Ethernet cable on your gaming console?
Look forward to hearing back from you.
Hayley
tatterz94
  • 5
Message 8 of 9
Hi Hayley,
I'm regularly getting under 50mpbs on both devices I've tested.
Unfortunately I'm not able to run an Ethernet cable to the console!
gary_dexter
  • 30.55K
  • 1.89K
  • 4.06K
Message 9 of 9
Then you still have no accurate way of ascertaining your actual speeds.
