  • 114
Message 1 of 9
packet loss help!
my boys have packet loss in their games, i checked and they are right.  we had this before and an engineer had to come out as power levels were out.  can you check and see if there is a problem?  i did a thinkbroadband monitor and it had a fair amount of red packet loss on the graph.
thanks
  • 7.1K
  • 526
  • 919
Legend
Message 2 of 9
Re: packet loss help!
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 114
Message 3 of 9
thanks for your quick reply.  here is the info :-
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
323000000
4.3
40
256 qam
24
2
203000000
4
38
256 qam
9
3
211000000
4
38
256 qam
10
4
219000000
4
40
256 qam
11
5
227000000
3.7
38
256 qam
12
6
235000000
3.7
38
256 qam
13
7
243000000
3.5
38
256 qam
14
8
251000000
3.7
40
256 qam
15
9
259000000
3.7
38
256 qam
16
10
267000000
3.9
38
256 qam
17
11
275000000
3.9
38
256 qam
18
12
283000000
4
40
256 qam
19
13
291000000
4.3
38
256 qam
20
14
299000000
4.5
38
256 qam
21
15
307000000
4.8
40
256 qam
22
16
315000000
4.5
40
256 qam
23
17
331000000
4.4
38
256 qam
25
18
339000000
4.1
40
256 qam
26
19
347000000
4.1
40
256 qam
27
20
355000000
3.7
40
256 qam
28
21
363000000
3.5
38
256 qam
29
22
371000000
3.2
38
256 qam
30
23
379000000
3.7
40
256 qam
31
24
387000000
4
40
256 qam
32
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.3
5467
18567
2
Locked
38.9
15799
17711
3
Locked
38.9
12595
24188
4
Locked
40.3
11008
24113
5
Locked
38.9
10638
23317
6
Locked
38.9
10219
22578
7
Locked
38.9
9106
23714
8
Locked
40.3
8875
22504
9
Locked
38.9
7990
21738
10
Locked
38.9
7505
21950
11
Locked
38.9
7302
49570
12
Locked
40.3
6722
20132
13
Locked
38.9
6358
23796
14
Locked
38.9
5891
21298
15
Locked
40.3
5553
20756
16
Locked
40.3
5683
18845
17
Locked
38.9
6408
39422
18
Locked
40.9
5883
18164
19
Locked
40.3
5543
17511
20
Locked
40.3
5461
17600
21
Locked
38.9
5736
45628
22
Locked
38.9
5239
17987
23
Locked
40.3
6025
23020
24
Locked
40.3
7004
49785
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
32600000
4.3
5120
64 qam
5
2
39400000
4.35
5120
64 qam
4
3
46200000
4.35
5120
64 qam
3
4
53700000
4.4
5120
64 qam
2
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Time
Priority
Description
01/08/2020 12:26:32
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 09:53:10
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 05:57:26
notice
DHCP Renew - lease parameters tftp file-cmreg-vmdg505-rtsxxl35016u+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/07/2020 05:57:26
Error
DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/07/2020 04:55:34
Error
DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/07/2020 09:22:42
critical
28/07/2020 22:53:42
Warning!
26/07/2020 09:09:3
notice
26/07/2020 09:09:3
Error
26/07/2020 07:33:46
Error
26/07/2020 07:30:3
critical
25/07/2020 20:27:9
Error
25/07/2020 12:53:30
critical
25/07/2020 07:45:18
Error
21/07/2020 19:04:1
critical
21/07/2020 10:38:33
notice
21/07/2020 10:38:33
Error
20/07/2020 22:09:10
Error
20/07/2020 20:25:50
critical
20/07/2020 09:39:50
Error
i've just done a reboot of the modem and also my router just in case that might help - i have the hub3 in modem mode and use an asus gaming router.
thanks very much for looking at this.
  • 114
Message 4 of 9
this is the broadband monitor graph:- ignore the latest solid red line, this is where i just rebooted the modem and router.  you can see the packet loss/latency spikes previously however.
  • 114
Message 5 of 9
previous photo had my IP address and was deleted, sorry about that, i've blanked it out in the above graph.  ignore the two latest red lines, these were me rebooting the modem and also the router.
thanks again
  • 1.18K
  • 74
  • 143
Message 6 of 9
Hi DoomGuy,
Thanks for using the forums to get your boy's games back up to speed, I'm guessing there has been a lot of moaning and groaning in the house recently? lol We'll see what we can do to troubleshoot this for you. First can you answer these questions for me -
•    How is the PC/console(s) connected to the internet?
•    Do all devices have slow buffering like when you stream Netflix or load something on Social Media?
•    Would you be able to do a speed test here - virg.in/speedtest – so we can see how your wired connection is performing please?
•    I also have a link here that I think are really helpful in this situation - intermittent connection
•    Last question, which game are you playing? And does your stuttering only happen whilst playing this game? The reason why I ask is that sometimes the game servers can be laggy if its an online game so I'd like to eliminate this from our list 🙂
Please let me know what you find out!
Megan_L
  • 114
Message 7 of 9
thanks for your reply.
all the boys pc's are connected by ethernet directly to the router.  i have an asus gaming router and use the hub in modem mode
we don't get buffering at all on videos etc., its on the fastest package and the download speeds are always great - usually above 350mps anytime i test it.  its just the odd packet loss/jitter that is the issue - although according to the boys it has been fine the last couple of days, so it seems to only happen once every week or two perhaps?  nothing major for me, but of course for young boys, that is a disaster!
i cant do a speedtest just now, but i can confirm that whenever i do it i get great speeds as expected, usually about 360 down and 32 up.  no issue with speed at all, its really great.
the games they play are fortnite and overwatch and a couple of others, all on pc.  i do beleive that the odd lag spike is actually the game servers fault.
i think that my boys are perhaps just overreacting a bit - the odd bit of packet loss once a week or two doesnt seem to bad to me.
i think that as long as my power levels etc. all look good from your end then i can't really see what else can be done.
thanks!
  • 114
Message 8 of 9
one more thing.  i've been testing speeds last 2-3 days.  i'm only getting 200 meg down.  upload seems ok at around 30ish.  i am on the 350mb package.
the testing was done with a pc directly plugged in by ethernet to the router.  i'm using an asus gaming router with the hub 3 in modem  mode.
i was previously getting 350-360 down all the time when i did periodical testing.
be good if you could check if any issues
thanks
  • 1.25K
  • 56
  • 115
Message 9 of 9
Hi Doomguy,
Can you please turn off modem mode so we can run some remote diagnostics, please?
Zoie
