on 19-08-2023 16:10
As subject states im getting horrible packet loss on discord and low upload and not near where i would expect for download speeds, given that this is more then likely my 5th? issue with this im looking to see if it can be resolved quickly
on 19-08-2023 16:16
See these.
______________
Can we check… are the issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
If both, check for any “known network faults in your location - Try in 2 places
1) Try the “check service,”Area status webpage (https://www.virginmedia.com/help/service-status)
2) Then also Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
_________________________
If nothing is reported there then,post up your Hub/network connection details and someone will check to see if there is a problem there. In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
on 19-08-2023 16:31
1 | 330750000 | -1 | 40 | 256 qam | 25 |
2 | 202750000 | 0 | 40 | 256 qam | 9 |
3 | 210750000 | 0 | 40 | 256 qam | 10 |
4 | 218750000 | 0 | 40 | 256 qam | 11 |
5 | 226750000 | -0.2 | 40 | 256 qam | 12 |
6 | 234750000 | 0 | 40 | 256 qam | 13 |
7 | 242750000 | -0.4 | 40 | 256 qam | 14 |
8 | 250750000 | -0.5 | 40 | 256 qam | 15 |
9 | 258750000 | -0.7 | 40 | 256 qam | 16 |
10 | 266750000 | -1 | 40 | 256 qam | 17 |
11 | 274750000 | -1.5 | 40 | 256 qam | 18 |
12 | 282750000 | -1.5 | 38 | 256 qam | 19 |
13 | 290750000 | -1.7 | 38 | 256 qam | 20 |
14 | 298750000 | -1.5 | 38 | 256 qam | 21 |
15 | 306750000 | -1.5 | 38 | 256 qam | 22 |
16 | 314750000 | -1.2 | 38 | 256 qam | 23 |
17 | 322750000 | -1 | 38 | 256 qam | 24 |
18 | 338750000 | -0.7 | 38 | 256 qam | 26 |
19 | 346750000 | -1 | 38 | 256 qam | 27 |
20 | 354750000 | -1 | 38 | 256 qam | 28 |
21 | 362750000 | -0.9 | 38 | 256 qam | 29 |
22 | 370750000 | -0.9 | 40 | 256 qam | 30 |
23 | 378750000 | -0.7 | 38 | 256 qam | 31 |
24 | 386750000 | -1 | 38 | 256 qam | 32 |
1 | Locked | 40.3 | 0 | 0 |
2 | Locked | 40.3 | 5 | 0 |
3 | Locked | 40.3 | 5 | 0 |
4 | Locked | 40.3 | 5 | 0 |
5 | Locked | 40.3 | 5 | 0 |
6 | Locked | 40.3 | 4 | 0 |
7 | Locked | 40.3 | 5 | 0 |
8 | Locked | 40.3 | 5 | 0 |
9 | Locked | 40.3 | 6 | 0 |
10 | Locked | 40.3 | 5 | 0 |
11 | Locked | 40.3 | 6 | 0 |
12 | Locked | 38.9 | 11 | 0 |
13 | Locked | 38.6 | 4 | 0 |
14 | Locked | 38.9 | 5 | 0 |
15 | Locked | 38.6 | 7 | 0 |
16 | Locked | 38.9 | 5 | 0 |
17 | Locked | 38.9 | 5 | 0 |
18 | Locked | 38.9 | 4 | 0 |
19 | Locked | 38.9 | 5 | 0 |
20 | Locked | 38.9 | 6 | 0 |
21 | Locked | 38.9 | 6 | 0 |
22 | Locked | 40.3 | 5 | 0 |
23 | Locked | 38.6 | 5 | 0 |
24 | Locked | 38.9 | 0 | 0 |
on 19-08-2023 16:31
1 | 23600000 | 38.2 | 5120 | 16 qam | 14 |
2 | 32599974 | 37 | 5120 | 64 qam | 13 |
3 | 39400007 | 37 | 5120 | 64 qam | 12 |
4 | 46199991 | 37 | 5120 | 64 qam | 11 |
1 | ATDMA | 0 | 0 | 14 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 19-08-2023 16:31
19/08/2023 16:27:15 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/08/2023 16:27:1 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/08/2023 16:23:7 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/08/2023 05:26:15 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/08/2023 02:10:4 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/08/2023 02:10:4 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
15/08/2023 20:17:41 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/08/2023 14:10:5 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
14/08/2023 14:10:5 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:02:31 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/08/2023 03:39:22 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/08/2023 03:38:35 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/08/2023 03:38:31 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/08/2023 03:38:31 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/08/2023 03:12:19 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/08/2023 00:33:48 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt062+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/08/2023 00:33:48 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/08/2023 15:46:16 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 19-08-2023 16:34
https://www.thinkbroadband.com/broadband/monitoring/quality/share/b3034b018493904b0702b4eedb7fdae31480cedf
on 19-08-2023 17:20
BQM link - is not a link to your BQM - can you link to "share live graph"
Looks as if there is an issue on the upstream connection with on channel dropping to 16 qam and multiple T3 errors - likely to need a Tech visit to investigate
on 19-08-2023 18:27
https://www.thinkbroadband.com/broadband/monitoring/quality/share/b3034b018493904b0702b4eedb7fdae314...
this is what is in the direct link box when i click share live graph
on 30-08-2023 11:17
so its been 2 weeks with no response, I have to wonder if its just virgin medias policy to be so awful with customer service? I've never once had this type of treatment from a company.
on 01-09-2023 14:52
I am now actively losing work performance due to virgin medias willful disregard to sort the problem out
