Anonymous
Not applicable
Message 1 of 11
not fit for purpose - drops off on multiple devices
Only creating this to track how bad the broadband service is and the poor customer service from virgin media.
and before service ask me to restart the hub.... yes I've already done that and am fed up doing it. And no, I'm not going to sit in a utility cupboard to work so that I can be plugged into the hub.
15/02: speed test shows less than 50mbps several times. Internet disconnected several times during the day, in particular during sales call.
16/02 0746: internet disconnected from surface pro
Anonymous
Not applicable
Message 2 of 11
Re: not fit for purpose - drops off on multiple devices
apcyberax
  • 33.38K
  • 1.87K
  • 5.93K
Message 3 of 11
is that using a wireless or wired connection?
Anonymous
Not applicable
Message 4 of 11
wireless. VM have already said I'll get better connection by being plugged in - the hub is in a utility cupboard so the thought of working from a utility cupboard for the foreseeable future just to get the wifi I paid for is not too appealing. It's not just the speed that's the issue - it keeps disconnecting from several devices intermittently. I've been disconnected once this morning already on a surface pro. Disconnected twice yesterday (during a sales call no less!).
Have never had this issue with hyperoptic or sky so am unwilling to accept their explanation of "that's just how wifi works".
apcyberax
  • 33.38K
  • 1.87K
  • 5.93K
Message 5 of 11
you do not pay for wifi. VM do not garantee wifi.
The wifi in the hub is poor. if you are getting the speeds and connection wired then your best option is to get your own better router or mesh system
Andruser
  • 5.52K
  • 970
  • 2.28K
Message 6 of 11
We're focusing on wifi as that is the problem you seem to be having, bear in mind that there are other potential causes like hub power levels, or connection noise.  But sticking with the wifi, when you say "utility cupboard", do you mean something like a wooden cabinet, or something more substantial, that you can walk into that has solid walls?
Anonymous
Not applicable
Message 7 of 11
walk into - typical UK style utility cupboard... the same utility cupboard where the virginmedia engineer installed the device. big enough to stand in, will be quite uncomfortable to work there just to plug into the device to avoid getting disconnected and the better speeds.
RedGooner
  • 1.87K
  • 66
  • 248
Super solver
Message 8 of 11
Always, Always and Always do a SPEEDTEST with a WIRED Device.
Red (VM SH2 AC Beta tester)
Running on 1Gbps VM service with SH4 in Modem Mode, with a ASUS RT-AC5300 router. With this setup I get Fantastic WIRED and WIRELESS Signals in my home. I dont work for VM. But I work in IT, and I know my tech.
My advice is at your own risk. If you are happy with my answers please press Kudo ?
Anonymous
Not applicable
Message 9 of 11
updating to keep track of when I get disconnected as requested.
disconnectedat 911am; wireless speed (yes yes I know, wireless speeds don't count...) when connected again are showing 15.49mbps
Anonymous
Not applicable
Message 10 of 11
