  • 16
Message 1 of 34
no wifi
could someone from virgin please get in touch with me because i am at my wits end i keep getting cut off the phone after listening to inane music for hours also no answer to emails i,m very close to stopping payments as i am a pensioner and need wi fi to keep in touch with family virgin sent me a new router witch does not work when my old one was perfect
  • 24.7K
  • 1.42K
  • 3.14K
Message 2 of 34
Re: no wifi
Have you activated the new hub?
  • 16
Message 3 of 34
Re: no wifi
yes i have also rebooted numerous times all i get is not in range i am sitting next to router
  • 11.81K
  • 925
  • 1.52K
Message 4 of 34
Re: no wifi
Can you get into the Hub using an ethernet cable connected device ?
Can you Login to the Hub Settings and navigate to the Connected Devices page - does it report any devices connected by wireless ?
Then navigate to the Wireless Settings and ensure that the 2.4GHz & 5GHz channels are enabled and broadcasting the SSIDs.
Mike Robinson
  • 16
Message 5 of 34
Re: no wifi
yes i am using an ethernt cable to my computer no devices connected it says wifi connected am trying wireless settings for channels
  • 16
Message 6 of 34
Re: no wifi
still the same i,m not tech savvy but my brain is fried  thanks for trying to help
  • 11.81K
  • 925
  • 1.52K
Message 7 of 34
Re: no wifi
Whenever possible use an ethernet cable connected device, ethernet is far more stable and is usually a faster connection than Wi-Fi.
Mike Robinson
  • 24.7K
  • 1.42K
  • 3.14K
Message 8 of 34
Re: no wifi
So is a wired connection working or no?
  • 16
Message 9 of 34
Re: no wifi
yes but the router only has a short cable from the box which is in living room which is no good for bedrooms I would have to run a20 metre cable up through the house
  • 24.7K
  • 1.42K
  • 3.14K
Message 10 of 34
Re: no wifi
WiFi is limited in range, especially on ISP provided hubs
