PJBart
new hub 4 and lost smart light connections
Hi - I've just switched to the hub 4 and now my smart lights are un responsive. How can i check if the hub is 2.4 or 5ghz?
jpeg1
  • 4.51K
  • 254
  • 728
Community elder
Re: new hub 4 and lost smart light connections
By default it will be operating on both bands with the same name (SSID).  If you want to change that you will need to log on to the Hub on 192.168.0.1 and follow the menus to the WIFI settings.
PJBart
Still no use.
Think I'll switch back to old hub. This one keeps dropping connections.
  • 2.86K
  • 215
  • 606
Trouble shooter
@PJBart wrote:
Still no use.
You can't as VM will have disabled it when they provisioned the Hub 4.
-tony-
  • 16.5K
  • 1.31K
  • 3.89K
@Adduxi wrote:
@PJBart wrote:
Still no use.
not 100% true - you can buy=t it might be an uphill struggle - you need to ring and get them to re activate the old hub
why did you change
regarding the smart lights - have you reset them up - they will still be looking for the old hub wifi - you need to press the button on them and start again - if they still will not work split the bands on the hub4
regarding the hub4 dropping connections - splitting the bands should help as will turning off smart wifi
____________________
Tony
Paulina_Z
  • 416
  • 15
  • 25
Hi @PJBart,
Welcome to our Community Forum! Thank you so much for your first post 🙂
I'm sorry to hear that you're not happy with your new Hub 4 and that you're experiencing some connection drop outs! Does this happen on all devices, or just on one or two?
Would you be able to set up a BQM link and let it run for over 24 hours, so we can see where the drop outs are?
Please keep us updated so we can look into this issue a little further for you.
Paulina_Z
