network congestion or localised issue?
I tend to get a lot of latency on my internet connection and have had problems with voip calls in the past couple months and I set up a BQM after looking for help online.  I have hub3 in modem mode and connect to router with ethernet and I've lost count of the number of times I have rebooted modem/router recently.  The BQM link below is from Sunday, but midweek is similar just spikes come earlier in the day (2-6pm), doesn't look great but I'm no expert.  I generally get reasonable speedtest results and I'm certainly not overloading my network connection when the latency peaks.  I don't know how to read the modem status information, but is this more likely to be congestion ??  any help appreciated!
https://www.thinkbroadband.com/broadband/monitoring/quality/share/cd96c8ec9f1fc37860aea76cae692d153c085d7b-16-11-2020
1218750000-3.236256 qam11
2202750000-2.736256 qam9
3210750000-336256 qam10
4226750000-3.536256 qam12
5234750000-3.736256 qam13
6242750000-3.736256 qam14
7250750000-3.736256 qam15
8258750000-3.536256 qam16
9266750000-336256 qam17
10274750000-2.937256 qam18
11282750000-2.737256 qam19
12290750000-2.537256 qam20
13298750000-2.237256 qam21
14306750000-237256 qam22
15314750000-1.737256 qam23
16322750000-1.737256 qam24
17330750000-1.237256 qam25
18370750000-138256 qam26
19378750000-137256 qam27
20386750000-1.537256 qam28
21394750000-1.538256 qam29
22402750000-1.538256 qam30
23410750000-1.537256 qam31
24418750000-1.937256 qam32
1Locked36.6380
2Locked36.6330
3Locked36.3460
4Locked36.6350
5Locked36.6870
6Locked36.6780
7Locked36.6720
8Locked36.39420
9Locked36.660585
10Locked37.354144
11Locked37.3250
12Locked37.3140
13Locked37.3711
14Locked37.6750
15Locked37.6240
16Locked37.6100
17Locked37.6230
18Locked38.620
19Locked37.6110
20Locked37.680
21Locked38.680
22Locked38.2110
23Locked37.6140
24Locked37.640
13260002940.5512064 qam4
23940004340.5512064 qam3
34619999840.5512064 qam2
45370000940.5512064 qam1
1ATDMA0010
3ATDMA0010
4ATDMA0000
  • 5.76K
  • 1.09K
  • 1.52K
Re: network congestion or localised issue?
Hello
Looking at the BQM certainly looks like a lot like congestion / high utilization on your local network, can you also post your network logs, as on your downstream there a couple of channels that have a high number of Post RS errors which could be a noisy line.
Regards Mike
Thanks Mike,
Here are the network logs.  I've been monitoring our LAN usage through the router as was worried the kids were saturating the home network with games/streaming etc but even now with kids at school and 1Mbps up and 3-5Mbps down across my entire LAN I'm seeing average latency around 50ms and max latency spiking off the chart and that's with 500Mb package.
16/11/2020 10:02:34noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/11/2020 00:02:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 18:11:7noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 14:01:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 22:55:23noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt078+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 22:55:23ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 01:38:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/11/2020 17:00:22noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 11:31:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 10:41:42Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 09:52:29criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 09:51:12criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 09:38:47criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 09:37:41criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 09:34:47Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 09:34:42Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 09:34:42criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/11/2020 09:34:38Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 5.76K
  • 1.09K
  • 1.52K
Hello
Looking at everything together I am pretty sure that your local area is having an issue with high utilization, if you hang around a member of the VM forum team will get to the post and do some further checks on their side.
Regards Mike
Is anyone from the VM forum team able to help with this, things only seem to be getting worse recently.  Experiencing >400ms pings this morning while trying to work.  Area reference is 20.
My BQM
  • 11.36K
  • 888
  • 1.45K
Phone it in as a bad connection (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
