forumarchive,nothingtosee,
bob671
Message 1 of 5
moving wifi hub
I have 2 v6 boxes, one for anupstairs TV and one in the lounge for downstairs TV.
I want to move the wifi hub from upstairs to downstairs.
Do I have to change any settings on the v6 boxes after moving the hub?
g0akc
  • 553
  • 59
  • 116
Rising star
Message 2 of 5
Re: moving wifi hub
I wouldn't have thought so.  How are the V6 boxes connected?
Maybe check in the V6 forum?
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
gary_dexter
  • 28.7K
  • 1.75K
  • 3.74K
Message 3 of 5
Re: moving wifi hub
How are you planning on moving the hub?
What cabling are you using?
bob671
Message 4 of 5
Re: moving wifi hub
All sorted, just reconnected hub to downstairs box via ethernet cable and splitter, then went into settings on V6 to connect to internet downstairs, and on the upstairs v6, re-configure the settings foe wire-less.
I am not technical at all but it was quite straightforward.
gary_dexter
  • 28.7K
  • 1.75K
  • 3.74K
Message 5 of 5
Re: moving wifi hub
You might want to check the levels on the hub to ensure they're all in spec still
