  • 19
Message 1 of 20
loss of internet hub reset
I am experiencing regular connection dropouts on my Virgin Hub 3.0 router. Here are the logs - I would be grateful if someone could interpret the data to see if there's an issue
1202750000-0.738256 qam9
2210750000-137256 qam10
3218750000-137256 qam11
4226750000-1.237256 qam12
5234750000-1.237256 qam13
6242750000-1.437256 qam14
7250750000-1.538256 qam15
8258750000-1.538256 qam16
9266750000-1.537256 qam17
10274750000-1.537256 qam18
11282750000-1.438256 qam19
12290750000-1.537256 qam20
13298750000-1.537256 qam21
14306750000-1.737256 qam22
15314750000-1.738256 qam23
16322750000-1.537256 qam24
17330750000-1.738256 qam25
18370750000-1.738256 qam26
19378750000-1.738256 qam27
20386750000-238256 qam28
21394750000-1.738256 qam29
22402750000-1.938256 qam30
23410750000-238256 qam31
24418750000-238256 qam32
1462000005.05512064 qam1
2257999704.85512064 qam4
3394000005512064 qam2
4326000004.925512064 qam3
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-rtsxl20016u+voc-b.cm
SFID84546
Max Traffic Rate230000061
Max Traffic Burst42600
Min Traffic Rate0
23/10/2020 20:01:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 18:16:58Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 13:06:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 11:34:18Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 10:28:18criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 09:01:46Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 22:38:47Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 20:11:31noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 18:34:13Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 15:51:4ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 15:29:45ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 14:29:46criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 14:11:49ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 14:03:56ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 13:47:54Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 13:35:13ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 13:24:52ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 12:47:3ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 12:39:31ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Tags (1)
  • 19
Message 2 of 20
Re: loss of internet hub reset
29/10/2020 18:06:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 19:37:9ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 03:15:20ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 1.73K
  • 81
  • 134
Message 3 of 20
Hi Madara,
Thanks for your post, I am sorry you are having issues I have checked your account remotely and there is an outage on your account the reference is C01135138 and the estimated fix date is today at 15:00. Let us know if you are having issues after the eta 🙂
Zoie
  • 19
Message 4 of 20
Hey zoie thanks for for replying i had the 4th engineer finally a good one who knows how to do his job come on 25/10/2020 checked all the wires and said he found a fault and replaced it so im just waiting to see if the problem is fixed or not.
Would you have any idea if i could get my money back for the last 3 mouths beacuse of the hub losing connection and timing out /turning on-off and for the call center telling me its the hub and kept on giving a new one everytime i phoned also for the 3 engineers for not checking the wires in the first place
thank you for your time
Madara
  • 6.93K
  • 359
  • 613
Message 5 of 20
Thanks for coming back to us.
It wouldn't be a full three month refund. no.
Compensation is given based on the automatic compensation policy
Kind regards,
John_GS
  • 19
Message 6 of 20
Replacing the wire didnt work 😞
01/11/2020 00:26:56
critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 19
Message 7 of 20
so is there anything i can do
01/11/2020 01:38:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/11/2020 01:17:43ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/11/2020 01:06:26ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 7.71K
  • 462
  • 486
Message 8 of 20
Hey Madara,
I've had a look from here this afternoon and everything is looking good from here, what issues are you having at the moment?
Emma_C - Forum Team
  • 19
Message 9 of 20
so its my hub for some reasion it loses connection and reboots on its own and every time it hapens this shows up on my networks logs
  • 12.23K
  • 947
  • 1.57K
Message 10 of 20
How are you connecting your device[s], Wi-Fi or ethernet cable ?
What is your connection like using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
