EthanT
Message 1 of 7
intermittent wifi
recently I have been having issues with intermittent connection on my wireless devices. Most devices only have infrequent intermittency issues, whilst my tablet is connected for 10 seconds to a minuet at a time before disconnecting. This happens for most of the day.
Here are my network logs.
11/02/2021 20:21:15noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/02/2021 23:39:49criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/02/2021 20:01:27noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/02/2021 20:01:27ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/02/2021 13:29:59criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
05/02/2021 22:53:22noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/02/2021 14:26:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/02/2021 17:40:9Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/02/2021 14:39:32noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/02/2021 14:39:32ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/01/2021 04:27:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/01/2021 02:56:16noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/01/2021 02:56:16ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 14:50:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 13:22:55noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/01/2021 13:22:55ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2021 06:25:45criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2021 01:22:55noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/01/2021 01:22:55ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/01/2021 00:25:34Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
13940002447512064 qam2
22580001745.5512064 qam4
33260000747512064 qam3
44620000447512064 qam1
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1ATDMA0010
2ATDMA0010
3ATDMA0000
4ATDMA0020
Downstream bonded channelsChannel Frequency (Hz) Power (dBmV) SNR (dB) Modulation Channel ID
1298750000340256 qam21
21387500002.740256 qam1
31467500003.240256 qam2
41547500003.440256 qam3
51627500002.940256 qam4
61707500003.240256 qam5
7178750000340256 qam6
81867500003.240256 qam7
9194750000340256 qam8
10202750000340256 qam9
11210750000340256 qam10
122187500002.740256 qam11
13226750000340256 qam12
142347500002.740256 qam13
15242750000340256 qam14
16250750000340256 qam15
17258750000340256 qam16
18266750000340256 qam17
192747500002.940256 qam18
20282750000340256 qam19
21290750000340256 qam20
223067500002.940256 qam22
23314750000340256 qam23
243227500002.740256 qam24
1Locked40.3280
2Locked40.3160
3Locked40.3350
4Locked40.3180
5Locked40.3310
6Locked40.9340
7Locked40.3310
8Locked40.3290
9Locked40.3430
10Locked40.3210
11Locked40.9120
12Locked40.3210
13Locked40.9120
14Locked40.3190
15Locked40.9210
16Locked40.9140
17Locked40.3180
18Locked40.9260
19Locked40.9180
20Locked40.3100
21Locked40.3130
22Locked40.3310
23Locked40.9320
24Locked40.3200
tehwolf
  • 1.65K
  • 270
  • 408
Superfast
Message 2 of 7
Re: intermittent wifi
I don't see much wrong with your stats - couple of timeouts in the logs, but spread out and that's not unusual.. one or two rcs parcial service messages, but again spread out so unlikely to be causing the issues you're seeing with wireless devices..
do you have anything that you can connect to the hub with an ethernet cable to see if you get the same drop outs? (inconvenient, yes, but worth testing if you can).
also worth setting up a BQM to see how the connection is performing - it'll take 24 hours to get a decent set of data, so the sooner you do it the sooner we can look at it 🙂
EthanT
Message 3 of 7
My pc is wired in and has no issues with internet connection and I have ran tests which showed no issue with my wired connection and during times of intermittency, my wired pc works without issue. The issue I'm having with the Wi-Fi is mainly just affecting one device a lot of the time with other devices facing the same issue but much less frequently. I also ran the built in ping test and caught it during a period of intermittency where it reported 3 packets sent but 0 received. I have just set up the BQM and so will have to provide results tomorrow.
tehwolf
  • 1.65K
  • 270
  • 408
Superfast
Message 4 of 7
when you post it back, select the "live graph" and then click the "sharing link" that will post it back here without your IP address..
EthanT
Message 5 of 7
https://www.thinkbroadband.com/broadband/monitoring/quality/share/16c13ec68247608b7b8c0980156b5f037a5dc545
tehwolf
  • 1.65K
  • 270
  • 408
Superfast
Message 6 of 7
So, whilst it's not a full 24h of data yet, the graph doesn't look too bad - couple of high spikes, but acceptable for a cable connection.. i'd say based on your stats and the BQM that your problem is just with the wifi rather than the connection..
you could try a different hub, though you'll probably face an uphill struggle with VM because they don't provide any guarantee about wifi performance and from all of their telemetry your connection will look fine.. you could also try refining your wifi network a little (by splitting the 2.4 and 5ghz bands into two separate networks) and seeing if that improves things.. but really, the best option you have is to buy yourself a decent router or mesh system and put the hub in modem mode.. prices start at about £100 for a reasonable system (maybe a little higher for a mesh system, depending on what offers are available) but it should improve things significantly for you..
EthanT
Message 7 of 7
I appear to have found a solution to my issue. The solution I found was to disable the Chanel optimisation and increase the band width of the 2.4 GHz and 5GHz from the factory settings to 20/40 MHZ for 2.4GHz and to 20/40/80 MHz for the 5GHz Chanel. I made this change of the Saturday and I have not had an issue with intermittent Wi-Fi so far.
