  • 5
Message 1 of 7
intermittent wifi and a Solid green light when it drops out
I have been getting intermittent WI-Fi drop-out for a while now but doesnt seem to be quite the same as others and as my partner and I are working from home I am hoping someone knows how to fix this.
It varies from day to day but is becoming more frequent that the WI-FI is dropping out, devices connected by cable are fine.
I don't think this is a signal issue as when the wi-fi connection drops out I get the solid green wi-fi light on the hub which suggests to me the problem is originating there and after about 10 minutes the connection is back.
I have followed through the online help but after doing the factory reset the help stops there but the problem continues.
I should mention that I have previously had problems the same coupled with an overheating hub (constant red light) so the hub was replaced but the wifi dropping out has continued.
I am getting errors showing on the logs as well.
04/11/2020 18:04:17noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 18:01:29Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 01:46:58ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 01:15:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 01:15:5criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 01:10:0Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 01:09:55criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 01:09:54Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 01:09:54criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/11/2020 14:46:44Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/11/2020 04:15:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 18:18:3ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/10/2020 04:14:5ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 20:27:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/10/2020 14:10:11ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
27/10/2020 01:07:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/10/2020 07:01:35ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 20:05:58ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 09:26:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
I really dont want to have to call them up again as it is such a nightmare to get anyone to think outside their scripted knowledge base.
Please help
Tim
Tags (1)
  • 11.49K
  • 891
  • 1.46K
Message 2 of 7
Re: intermittent wifi and a Solid green light when it drops out
Try a factory reset the Hub using this exact method ...
DO NOT DO THIS if the password on the base of the Hub is not legible or missing.
Instructions for Hub 3
Disconnect all unneeded ethernet cables from the rear of the Hub.
With the Hub Powered on use a paperclip or similar (I use a mobile phone SIM Slot tool) and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Once a steady white and no other lights are illuminated check your system again.
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 5
Message 3 of 7
i will give this a go today and let you know, cheers
  • 5
Message 4 of 7
OK did the reset as suggested, just unplugged all the ethernet cables in the end while it reset.
the lights went off, all flashed red and all flashed green after the 60 seconds then i released the button but I am not sure it actually did reset.
The time before I reset it holding the reset button for 10 seconds and it reset the password to default but this time it didn't and was still set to what i had set it to.
does that sound right?
  • 5
Message 5 of 7
Update: unfortunately it didnt help. WI-Fi just cut out again with same green light. any other suggestions?
Message 6 of 7
Experiencing the same issue. It happens every couple of hours. Also tried the reset instructions, which have done nothing.
The wifi light turns solid green for around 30 seconds, then starts flashing at inconsistent rates before turning off and the wifi restarting. It's been happening like this for quite a while now but is not bearable as we are now back in lockdown and relying on the wifi.
  • 5
Message 7 of 7
I tried the reset above again as the first time as it didn't actually reset the password and second time round it did reset everything and it has been 2 days without problem which is a good sign.
