funboy-jon
Message 1 of 7
intermittent connection
I've been having issues with the ethernet connection to my hub for quite a while now. recently the wi-fi has started dropping off too.
My hub is giving out this error message
Does anybody have any ideas ?
Z92
  • 2.27K
  • 188
  • 352
Problem sorter
Message 2 of 7
Re: intermittent connection
That's a common error message, you need to post the rest of the log, and the other tabs as well.
funboy-jon
Message 3 of 7
26/04/2021 08:06:28 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2021 17:43:53 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2021 17:43:44 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2021 17:43:3 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/04/2021 17:41:46 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/04/2021 16:17:56 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/04/2021 18:15:56 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/04/2021 18:15:56 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/04/2021 00:37:20 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/04/2021 06:15:55 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/04/2021 06:15:55 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/04/2021 20:40:56 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/04/2021 18:15:55 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/04/2021 18:15:55 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/04/2021 19:15:56 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/04/2021 06:15:56 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/04/2021 06:15:56 Error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/04/2021 20:55:27 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/04/2021 18:15:54 notice DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Natalie_L
  • 2.64K
  • 118
  • 215
Message 4 of 7
Hi funboy-jon
Welcome to the Community and thank you for posting.
I am sorry to hear you are experiencing issues with your service.
Could you please also post upstream / downstream logs to the thread for us to review?
Also, do you have a BQM ( Broadband quality monitor) running at the moment? If so, can you please supply the link and we will be happy to take a look 🙂
Nat
funboy-jon
Message 5 of 7
12990000005.838256 qam21
21390000004.337256 qam1
31470000004.537256 qam2
41550000004.837256 qam3
5163000000537256 qam4
61710000005.137256 qam5
71790000005.337256 qam6
81870000005.437256 qam7
91950000005.338256 qam8
102030000005.338256 qam9
11211000000537256 qam10
122190000004.938256 qam11
132270000004.637256 qam12
142350000004.637256 qam13
152430000004.437256 qam14
162510000004.338256 qam15
17259000000438256 qam16
182670000003.538256 qam17
19275000000437256 qam18
20283000000538256 qam19
212910000005.438256 qam20
223070000005.838256 qam22
233150000006.138256 qam23
243230000006.438256 qam24
funboy-jon
Message 6 of 7
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
12580000041512064 qam4
23260000041512064 qam3
33940000041512064 qam2
44620000041512064 qam1
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1ATDMA00330
2ATDMA00320
3ATDMA00280
4ATDMA0021
Sasha_W
  • 973
  • 39
  • 74
Message 7 of 7
 Hi @funboy-jon
Thanks for posting back to us,
So from taking a look at your account, everything does look okay from our side, there are no faults or outages.
But have seen you haven't rebooted your hub in over 2 months, would you mind just carrying out a pin hole reset just so we can see if there are any issues.
Sasha - Forum Team
