Message 1 of 5
iMac Ethernet IP address issue
Hi, appreciate that this will come across as a numpty query but I am trying to install a BT WholeHome wifi set up and connect it to the Hub3. Before switching off the WIFI from the Hub I was just trying to get the MAC to connect to the HUB with a cable but I am unable to get a valid Ethernet IP address on my MAC that then connects to the Hub3. Whilst the MAC does show that the Ethernet is connected (and only on the 4th port) and I am using DHCP the MAC does not show up in the Hub3 devices and the Internet only works when the WIFI is switched on. I have tried different cables and got the same response. So I guess there is a simple config in the MAC that I need to do but also wondering whether there is something I need to do with the Hub setting? Has anybody else had a similar issue?
Big thanks in advance
Sal
  • 25.12K
  • 1.44K
  • 3.2K
Message 2 of 5
Re: iMac Ethernet IP address issue
Plug the Mac into the spare Ethernet port on the WiFi disc - does that work?
Message 3 of 5
thanks for that, but there is only one port on the disc and I think that is the one which should connect to the hub.
  • 25.12K
  • 1.44K
  • 3.2K
Message 4 of 5
Ah ok. You have the standard discs then.
Disabling the WiFi won’t stop Ethernet connections direct to the hub from working.
Message 5 of 5
thanks, will give it a try.
