If it ain't broke, don't try to fix it.
You would effectively be a beta-tester for new equipment - which is proving to be as problematic as everyone predicted.
If you are comfortable with that and you are invited - them go ahead but do not return your Hub3 hang on to it for a while so you can easily get it re-activated to replace the Hub5 with no down time.
