ippy
hub3 won't accept the default password
I keep getting devices dropping out when using the wifi on my hub3.
I was wondering if I'm logged into the lower range 2.5 instead of the 5
So i wanted to log onto the router settings but it will not accept the default password, so I'm unable to change any settings.
My phone suggests the security it low too on the connection.
Any help gratefully received please.
  • 20.7K
  • 2.2K
  • 3.66K
Re: hub3 won't accept the default password
Is it an iPhone on iOS14 by any chance?
https://community.virginmedia.com/t5/Networking-and-WiFi/iOS-14-Weak-Security/td-p/4410050
Note to log into the Hub3 you use the "settings" password not the "wifi" one.  Both are printed on the Hub if it still doesnt work over wifi connect on an ethernet cable connected device and try again or vica versa - also try using a different browser
ippy
Thanks for the help.
IPhone X latest software..
I’ll try the settings password tomorrow, thanks for your help.
  • 20.7K
  • 2.2K
  • 3.66K
"IPhone X latest software.."
Follow the procedure in the link then
ippy
Thanks for the link. I changed the security as suggested.
just one more question, when I log my devices in, how do I know if it’s on the 2.5 or 5 channel ?
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.93K
You may be as well refining your Wi-Fi management, it will certainly help keeping track of your Wi-Fi frequencies.
Best done with a cable connected device.
Instructions for Hub 3, Hub 4 is similar.
Log in to the Hub.
Advanced Settings > Wireless > Security > Add 2 to the 2.4GHz Channel name [SSID] > Add 5 to the 5 GHz Channel name [SSID] > Click ‘Apply Changes’
Log out of the Hub then reboot using this method ...
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
While the Hub is powered off go around all the accessible co-ax connectors inside and outside to ensure that they are finger tight.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then try your Wi-Fi again.
You will need to reconnect all you Wi-Fi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
When you connect the devices do it at the furthest point from the Hub that the device will be used.
