hub
Hi can someone help with sign into hub asks for password but wont accept it.
  • 323
  • 46
  • 76
Fibre optic
Re: hub
Are you using the default settings (which are on a sticker on the bottom of the hub or on a pull-out card, depending on your hub version) or have you previously changed the password to one of your own?
If you are using the defaults, make sure you are entering the admin password for the hub and not the SSID password for the wireless.
  • 493
  • 6
Up to speed
Re: hub
I'm having the same sort of issue, WIFI has been awful the last couple of days but trying to sign into the hub says someone else is currently signed into the settings page.
Restarted hub, same issue, restarted hub again same issue so i thought right lets restart computer, same issue so as a last resort i did a pinhole reset.
Low and behold, same issue, keeps saying someone is signed into the settings which is impossible
  • 7.07K
  • 524
  • 915
Legend
Re: hub
@Spoony36 wrote:
I'm having the same sort of issue, ... snip ...
If you want assistance please start your own thread.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
