hub issues
jamesrm
my broadband hub has been intermittent for over a week and has now failed despite numerous resets. I was advised on the phone that there was a local issue? can you please advise if a replacement is necessary.
thanks
8 REPLIES 8
Is the Hub broken, or is it your broadband circuit is down?  Either way, a VM Mod will pick this up in a day or two and discuss with you.  If you need is urgent, you will need to ring VM.
For local issues... Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
Carley_S
Hi @jamesrm
Welcome back to the community forums
Sorry to hear you're having issues with your services at this time.
Looks like the local issue has since been resolved and I cannot see anything else of concern. Your hub specs and levels all look good at our side.
If you're still having any concerns, please reboot all your equipment since the outage has been resolved and let us know if the issues persist at all.
Here to help 🙂
Virgin Media Forums Agent
Carley
Hi Carley
the intermittent problem is still continuing. I've rebooted again but still persists
thanks
James
Hi @jamesrm, thank you for the update.
Are you experiencing the same problems on devices connected via ethernet cable?
If not, have you tried running checks on the Virgin Media Connect app? You can access the app by clicking here
Regards,
Daniel
Hi Daniel
Neither of my laptops have an ethernet connection. Just the TV wired directly to the hub.
I've reset the hub again but no change
thanks
James
Perform a full Restart both laptops specifically use:      Shutdown or sign out >>> Restart
Hello jamesrm,
Thanks for replying.
Can we just ask how things are today?
Have you been able to connect okay with out loss of connection?
Gareth_L
