wyre
  • 338
  • 10
Superfast
Message 1 of 9
hub 5
Is the hub 5 still just on trial  if it is  not can i swap my hub 4 please
  • 13.91K
  • 1.08K
  • 2.82K
Message 2 of 9
Re: hub 5
Yes, not been generally released yet. Why would you want one, latest, greatest, biggest is not always best.
wyre
  • 338
  • 10
Superfast
Message 3 of 9
Re: hub 5
Just  asking  that's  all and sometime soon  i  getting  something   that  works on ivp6 Just wondering  if  it would still  work on the  hub4 which  is ivp4.only.as far as  I understand
  • 6.82K
  • 593
  • 1.79K
Message 4 of 9
Re: hub 5
VM UK do not use IPv6 as yet.   If you really need IPv6, forget VM and go for an Openreach based supplier, or try a tunnelled IPv6 from Hurricane Electric etc.
  • 13.91K
  • 1.08K
  • 2.82K
Message 5 of 9
Re: hub 5
The hub5 works with WiFi 6 not IP V6, totally different beasts.
deasmi
  • 65
  • 13
Dialled in
Message 6 of 9
Re: hub 5
If you do use a tunnel then make sure you are on a Hub 4 as the Hub 3 has terrible issues and will throttle you to <20mbps.
https://www.ispreview.co.uk/index.php/2020/09/quick-update-for-virgin-media-speed-issues-on-ipv6-tun...
I do not know if they ever released a fix for this, I moved to 1gbps just to get a Hub 4 to get round this problem, thankfully it did fix the issue and I have ipv6 at line speed.
fayz
  • 45
  • 6
Dialled in
Message 7 of 9
Re: hub 5
Can you confirm if you get the full 1gbps speeds using the HE tunnel? I tried it on the hub 4 and got around 300mbps max, Going to test the hub 5 tonight.
It's annoying if the speed cap is still there as it's guaranteed virgin are doing there classic 'we don't throttle but prioritise' whatever that means...
  • 13.91K
  • 1.08K
  • 2.82K
Message 8 of 9
Re: hub 5
Do NOT duplicate posts or coat-tail on a post from March.
Chris_W1
  • 6.57K
  • 276
  • 442
Message 9 of 9
Re: hub 5
Hi fayz, thanks for the message.
I am sorry to hear that you are having an issue with the broadband and this is not the experience which we want you to have with us.
Can you confirm how it went with the hub 5 and if things have now improved.
Kind regards, Chris.
