how to book an engineer to come out and fix my intermittent broadband
HI I cannot get through on the phone and it suggests I go here. How do I book an engineer to come out and fix my fault please?
Tags (2)
  • 11.37K
  • 787
  • 1.6K
Re: how to book an engineer to come out and fix my intermittent broadband
You post details of your problem here and if we or the forum staff can't help then they may book a technician if they feel its a job a tech can fix
I work for Virgin Media and my posts are my own opinions
well my internet keeps dropping every few minutes , it may or may not come back within the next 30 mins or so. I’ve tried making sure the cables are reseated and rebooted the router many times .
the router says access to the internet is denied at that point .
‘This has been going on for about 2 weeks .
‘please advise
thank you
cormac
  • 6.49K
  • 482
  • 851
Hero
How are you connecting your device, Wi-Fi or ethernet cable ?
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
