  • 7
Message 1 of 13
how long to upgrade broadband speed- no support
i have recently upgraded my broadband from 200mb to 500mb however the speed has not improved, i have been unable to get through to support by tech team or phone chat. any idea how long it takes for upgrade, i have rebooted and factory reset throughout the day but have not seen a increase in speed
  • 24.31K
  • 1.39K
  • 3.09K
Message 2 of 13
Re: how long to upgrade broadband speed- no support
When did you request the upgrade?
If you go to the admin page and look at the logs, what is given under the "Configuration" tab?
Copy and paste the data on that page back here as text please.
  • 7
Message 3 of 13
today around lunchtime the advisor said it should take 15-30 mins
here is the log i think
09/11/2020 16:54:10 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 16:53:48 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 14:31:16 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 14:11:16 Warning! LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 20:31:47 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 20:30:31 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 20:30:31 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 20:30:30 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 20:30:29 Warning! Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 20:30:27 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 20:30:27 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 20:30:26 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 20:30:26 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 20:30:25 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 20:30:20 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 20:24:57 notice SW download Successful - Via Config file
08/11/2020 20:22:38 notice SW Download INIT - Via Config file
01/01/1970 00:02:37 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 19:59:28 notice LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0
  • 24.31K
  • 1.39K
  • 3.09K
Message 4 of 13
That’s the network log. Click on the tab that says configuration.
  • 7
Message 5 of 13
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
UBsgvca69834ncxv9873254k;
SFID 16944
Max Traffic Rate 575000000
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 16943
Max Traffic Rate 38520000
Min Traffic Rate 0
Max Concatenated Burst 16320
Scheduling Type BestEffort
  • 24.31K
  • 1.39K
  • 3.09K
Message 6 of 13
Network access
Allowed
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
SFID 16944
Min Traffic Rate 0
SFID 16943
Min Traffic Rate 0
Yes you’re on the 500Mbps speed package as shown in bold
You’ll need to Speedtest with a wired connection not wireless.
  • 7
Message 7 of 13
i have ethernet connected but only getting speed test of 80mb using ookla
  • 24.31K
  • 1.39K
  • 3.09K
Message 8 of 13
From what device?
What spec is the cable?
Are you wired direct to the hub or via a switch or powerline plug?
  • 7
Message 9 of 13
laptop not sure what spec the ethernet cable is and yes plugged in directly to the modem
  • 24.31K
  • 1.39K
  • 3.09K
Message 10 of 13
80Mbps possibly indicates either a CAT5 cable or the laptop only has a 10/100 network card.
The cable spec will be printed on the cable.
