  • 5
Message 1 of 10
high latency considerably slowing down my work (from home)
Good morning, I hope this is a good way to find some assistance. I chose to contact you via the community, rather than calling, to be able to attach some screenshots explaining the issue.
I am experiencing what seems to be a high latency issue which causes any action I am doing to freeze for a few seconds every minute or so, before I can continue to work (actions like writing on Word/Excel, opening a (small) picture/screenshot, even renaming a file, switching between open applications).
I work mainly with Excel, Word, memoq (a translation tool), seldom using the Internet (opening max 3 windows at the same time). Outlook constantly open.
This has been happening every day since last month, from around the 13th of October, I think. Previously, my connection was excellent, I had never any issues with working from home (since March), including browsing files on our server, downloading files, checking videos.
I work from home with a Surface laptop, connecting to the company VPN.
I have contacted our IT  team for help, but apparently this issue is not related to company hardware/software. They helped me identify what seems to be a high latency issue with my Internet provider.
I attach some screenshots with some data, hoping it can help shade some light on the problem.
I would be grateful if I could get some assistance from VirginMedia.
Thanks in advance!
Silvia
Virginmedia high latency1.pngVirginmedia high latency2 with timeout.pngVirginmedia high latency3.pngVirginmedia high latency4.pngVirginmedia high latency5 with timeout.pnglatency test1.pnglatency test2.png
  • 25.14K
  • 1.44K
  • 3.2K
Message 2 of 10
Re: high latency considerably slowing down my work (from home)
“Latency” has no effect on applications like word, excel etc.
  • 12.27K
  • 950
  • 1.57K
Message 3 of 10
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Disable any VPNs that you have running.
Mike Robinson
  • 12.27K
  • 950
  • 1.57K
Message 4 of 10
Can you please
Mike Robinson
  • 12.27K
  • 950
  • 1.57K
Message 5 of 10
Which Hub do you have ?
What is your contracted speed ?
What speeds do you get at >> speedtest.net << with a direct connection using a Cat 5E or better cable between the Hub in Router Mode and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
  • 5
Message 6 of 10
Hi Mike,
Thanks a lot for reaching out.
1314750000-0.538256 qam23
21387500002.238256 qam1
31467500002.240256 qam2
4154750000240256 qam3
51627500001.738256 qam4
61707500001.740256 qam5
71787500001.438256 qam6
8186750000138256 qam7
91947500000.938256 qam8
102027500000.738256 qam9
112107500000.238256 qam10
12218750000038256 qam11
13226750000-0.238256 qam12
14234750000-0.738256 qam13
15242750000-0.938256 qam14
16250750000-1.238256 qam15
17258750000-1.738256 qam16
18266750000-2.238256 qam17
19274750000-138256 qam18
20282750000-0.738256 qam19
21290750000-0.538256 qam20
22298750000-0.538256 qam21
23306750000-138256 qam22
24322750000-0.738256 qam24
1Locked38.93500
2Locked38.66613
3Locked40.351514543
4Locked40.3850
5Locked38.9470
6Locked40.3410
7Locked38.9460
8Locked38.9582263
9Locked38.9760
10Locked38.6260
11Locked38.9350
12Locked38.9401103
13Locked38.696049
14Locked38.61210
15Locked38.6760
16Locked38.61986
17Locked38.6880
18Locked38.95040
19Locked38.94330
20Locked38.93060
21Locked38.62140
22Locked38.93730
23Locked38.93180
24Locked38.62950
13260000045.3512064 qam5
23940000045.3512064 qam4
34620000046.8512064 qam3
45370000046.8512064 qam2
2ATDMA0010
3ATDMA0010
4ATDMA0000
  • 5
Message 7 of 10
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
A,.iyewrkldJKDHSUBsgvca69
SFID30012
Max Traffic Rate117000047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID30011
Max Traffic Rate10500047
Max Traffic Burst16320
Min Traffic Rate0
Max Concatenated Burst16320
Scheduling TypeBestEffort
12/11/2020 12:11:8Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 11:32:32noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 11:32:32ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 07:37:21Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/11/2020 00:57:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/11/2020 15:42:19Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 18:38:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 12:31:34Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 11:00:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 06:07:33Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 05:50:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/11/2020 00:05:40Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 23:15:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 06:54:18noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/11/2020 06:54:18ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
06/11/2020 16:49:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 20:35:32Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 18:54:18noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 18:54:18ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/11/2020 17:46:2Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 5
Message 8 of 10
My BMQ
Thank you, Mike.
I'm finally able to give it a try, after finishing work and disconnecting from the VPN.
If you have any other info for me, thank you in advance.
Have a nice weekend.
Silvia
  • 1.82K
  • 105
  • 154
Message 9 of 10
Hi silviagoldhawk,
Thanks for your post and apologies for the delayed response. Are you still having latency issues? Have you been able to test the connection without the VPN? Our remote diagnostic is not currently showing any issues with your connection.
Cheers,
Corey C
  • 5
Message 10 of 10
Dear Corey,
Thank you very much for your reply and for letting me know that, according to your diagnostic, my connection is fine!
Today I was finally able to test the same applications with a workaround to the VPN and it is much better.
I don't seem to notice the same issue.
So there is indeed nothing wrong with the connection, sorry for the false alarm!
Thanks for coming back to me, much appreciated.
Have a nice day!
Silvia
