andrewmm
  • 227
  • 14
Up to speed
Message 1 of 5
hidden network when hub wifi turned off
When I turn off the wifi from the virgin Hub
    I still have this hidden network broadcasting from it ( as detected on a wifi scanner )
  when I unplug hub power, hidden network disappears,
why if I turn off the hub wifi is it still broadcasting ?
Netgodude
  • 7
Message 2 of 5
Re: hidden network when hub wifi turned off
Hello.
This would be the public WiFi network on all vm routers that serves virgin go WiFi.
I would not worry about it.
Jim.
  • 16.32K
  • 713
  • 1.6K
Message 3 of 5
You can opt out of public WiFi on you account but might not work so if you want to stop it use modem mode.
andrewmm
  • 227
  • 14
Up to speed
Message 4 of 5
thanks ,
I thought I had signed out of the community share bit, I do not use outside virgin wifi
I did use modem mode for a while,
     but was finding the firewall was using was having problems keeping up with the 350 M download speed,
      what firewall device do you use ?
  • 16.32K
  • 713
  • 1.6K
Message 5 of 5
I use ZYXEL security firewalls but you likely need a home router that does hardware NAT for speed like this:
https://www.amazon.co.uk/ZyXEL-Armor-Multi-Gigabit-AC2600-Router/dp/B08KGSQWTT/ref=sr_1_3?dchild=1&k...
