burnssimon
  • 23
Message 1 of 13
get set for WiFi hotspots
Pressed it, it thinks about it, then said something went wrong.
Happens if I'm at home on the WiFi, at work on the WiFi, or using mobile data.
BenMcr
  • 21.59K
  • 2.35K
  • 4.36K
Message 2 of 13
Re: get set for WiFi hotspots
What device do you have?
burnssimon
  • 23
Message 3 of 13
Hub 3.0
BenMcr
  • 21.59K
  • 2.35K
  • 4.36K
Message 4 of 13
Sorry I meant what mobile device?
burnssimon
  • 23
Message 5 of 13
A Pixel 4
BenMcr
  • 21.59K
  • 2.35K
  • 4.36K
Message 6 of 13
That'll explain it. The Connect app can't currently configure an Android 11 device for the hotspots.
If you have a Virgin Mobile SIM you can use the instructions here to configure access to the 'Virgin Media' hotspots in the UK
https://www.virginmedia.com/help/sim-based-wifi-eap-profile-settings
burnssimon
  • 23
Message 7 of 13
Any update for Android 11 users? It's nearly four months since it's release...
pabx
  • 20
Message 8 of 13
workaround doesn't work
Samsung Note 20 Ultra 5G.  Supplied by Virgin
Message is -" couldn't authenticate connection"
Emily_G
  • 4.82K
  • 209
  • 286
Message 9 of 13
Thanks for the post Pabx.
We're not aware of a known issue regarding this at the moment.
What shows for you when you attempt to join a hotspot?
Thanks, Emily.
pabx
  • 20
Message 10 of 13
Thanks for following up Emily
I try connecting to "Virgin Media" instead of the router.   It says "Couldn't authenticate connection".  - I tried the AKA workaround.
When out of the house I don't pick up any wifi except through mobile data, and that is patchy here - the 4G reception is not great and no 5G where I live
This is a Samsung Note 20 Ultra 5G.  Everything worked fine on my Note 9.
Other parts of the Virgin connect app seem ok
