  • 9
Message 1 of 18
ftp problems connecting to my website to upload
Hello
I've played with this a lot and now think there may be a block or firewall at the virgin media end so I can't connect into my ftp (there is no block at the ftp server, and the software is all working).  I can connect on my mobile on mobile data, and friends can connect to it so it is my virgin media?  can someone from virgin please message me to do checks / correct my account?
many thanks
Trev
Tags (2)
  • 24.94K
  • 1.44K
  • 3.17K
Message 2 of 18
Re: ftp problems connecting to my website to upload
Who hosts the site?
Chances are they are blocking your public IP
  • 9
Message 3 of 18
I've checked that with them and they aren't / can't see any problems their end.
it would be good not to see if virgin are?
  • 24.94K
  • 1.44K
  • 3.17K
Message 4 of 18
Virgin won’t be blocking it no.
What are the results of a tracert to the IP of the server?
  • 9
Message 5 of 18
I'm not sure what that is?
But yes they think it is Virgin, so how would I get them to run tests etc?  I'm pretty good but no expert in computers to that level so really I want someone to look into it / solve the problem / issue?
could you advise 🙂 thanks
  • 24.94K
  • 1.44K
  • 3.17K
Message 6 of 18
Open a command prompt, type:
tracert <servername/IP>
Then hit enter and let it run. Copy and paste the results back here.
I'm 99.99999% certain your webhost is blocking your public IP and the person you spoke to had no clue and was fobbing you off.
  • 12.06K
  • 939
  • 1.54K
Message 7 of 18
What is the website address that you are trying to upload to ?
Mike Robinson
  • 9
Message 8 of 18
I'm on a MacBook pro
so terminal doesn't produce much.. not sure if thats the correct place to put it
-bash: syntax error near unexpected token `newline'
Trevors-MacBook-Pro:~ trevorwilliams$
  • 9
Message 9 of 18
its not a website, its the ftp.  so it is updating my website.
ftp.trevwilliams.co.uk
but I can connect using eg mobile date network.. so the issue is somewhere between the server and virgin and they must be a block somewhere (I think) would be great to have someone from virgin run a check their end like the ftp host did?
  • 24.94K
  • 1.44K
  • 3.17K
Message 10 of 18
You need to ask the webhost to unblock your public IP. That's it. Simple.
EDIT: I can trace to it successfully:
