on 29-09-2022 20:04
I have just upgraded to a Hub 5 and I am having trouble connecting a device to the wifi.
It was connected to the previous hub 3 no problem. I have set up the Hub with a private and a guest network but the device cannot see either of the networks. Every other device of mine and any visitor I have have found the 2 networks and have connected fine but this device simply cannot find the networks. It finds 3 of our neighbours networks but not our own.
Its located in an area with a very strong signal for the wifi showing on everyone elses devices that are connected.
I assumed it was an issue with the device so had an engineer come out from the company that installed it but said there is nothing wrong with it. He asked the question as to whether there are any settings within the modem/hub that can block a device from finding it.
Help needed please!!!!
on 29-09-2022 22:13
on 29-09-2022 23:24
on 29-09-2022 23:26
on 29-09-2022 23:38
on 30-09-2022 00:01
thanks for your help. I'll try to find out more about the security for the juke box connections
on 02-10-2022 15:12
Thanks for the update mjones1106,
Can I ask is the issue still present?
Let us know,
on 03-10-2022 20:28
Yes we are unable to change the device setting and since then we have had a laptpo that is unable to discover either network.
Martin
on 06-10-2022 08:17
Hi Martin,
Thank you for reaching back out, were you able to get more information on the Juke box website/ manual to fix your connection issue, in regards to the laptop which also cannot connect what make and model is it, can you cannot using an Ethernet?
Paul.
on 04-09-2023 19:13
Did you ever resolve this? I have one laptop that cant see my hub. Every other device works fine and the kaptop can see all other networks.
