  • 65
Message 1 of 10
continuing dropouts after 3 visits
After 3 visits this is not getting stupid,still getting dropouts at various times of the day,all 3 engineers found 3 different faults,each time everything was fine for a day or two then went back to dropping out,the only thing left to change is the hub itself,so if i could have a hab 4 that would be great and hopefully solve my problem.
  • 65
Message 2 of 10
Re: continuing dropouts after 3 visits
22/10/2020 10:12:4Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 10:09:59criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 10:07:38Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/10/2020 10:07:38criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 23:56:6Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 23:46:58criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 23:43:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 23:28:56criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 15:35:14Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 15:34:55criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 15:34:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 15:32:51criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 15:32:26Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 14:35:1criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 06:53:55Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 06:53:55criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 06:53:53Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/10/2020 05:24:56ErrorDHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/10/2020 23:55:21ErrorDHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/10/2020 21:50:15Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 65
Message 3 of 10
13870000003.540256 qam32
22030000000.738256 qam9
32110000000.938256 qam10
42190000000.938256 qam11
5227000000138256 qam12
62350000000.738256 qam13
72430000000.538256 qam14
82510000000.738256 qam15
92590000000.740256 qam16
102670000000.438256 qam17
112750000000.740256 qam18
122830000000.938256 qam19
132910000001.440256 qam20
142990000001.938256 qam21
15307000000240256 qam22
163150000002.438256 qam23
173230000002.740256 qam24
18331000000340256 qam25
193390000003.240256 qam26
203470000003.240256 qam27
21355000000340256 qam28
223630000003.540256 qam29
233710000003.740256 qam30
243790000003.740256 qam31
1Locked40.91668317449366
2Locked38.9157948893527839
3Locked38.6134121462920286
4Locked38.9132138622937270
5Locked38.9129649372810427
6Locked38.9127515292915436
7Locked38.9118162092635221
8Locked38.997398531794657
9Locked40.393412541926651
10Locked38.9105007252421143
11Locked40.395857952039695
12Locked38.980238981597740
13Locked40.967691481454403
14Locked38.963815691349221
15Locked40.355175281177774
16Locked38.948392271092145
17Locked40.34280605903731
18Locked40.33448064654964
19Locked40.32867790600006
20Locked40.32731746528527
21Locked40.32739513500369
22Locked40.32629720566255
23Locked40.32481428538580
24Locked40.32119361454488
  • 65
Message 4 of 10
1537000004.7512064 qam2
2603000444.7512064 qam1
3393999514.6512064 qam4
4461999224.625512064 qam3
3ATDMA0000
4ATDMA0000
  • 25.23K
  • 1.45K
  • 3.21K
Message 5 of 10
A new hub won’t solve it
  • 12.3K
  • 952
  • 1.58K
Message 6 of 10
Your Pre & Post RS Error counts are very high.
In an ideal world they would be at zero and stay there. To zero them can you reboot the Hub using this method and then keep an eye on the counts.
Switch the Hub off using the small switch on the rear of the Hub next to the power cord and pull the PSU plug from the wall socket.
Give it a good 5 minutes put the plug back in and switch the Hub back on.
Allow the Hub a few minutes to fully restart then check your error count again in one hour.
Mike Robinson
  • 65
Message 7 of 10
Ok here is the error count after an hour
13870000003.740256 qam32
22030000000.938256 qam9
3211000000138256 qam10
4219000000138256 qam11
62350000000.938256 qam13
8251000000138256 qam15
9259000000140256 qam16
102670000000.738256 qam17
11275000000140256 qam18
12283000000138256 qam19
132910000001.540256 qam20
14299000000238256 qam21
153070000002.240256 qam22
163150000002.538256 qam23
173230000002.940256 qam24
203470000003.440256 qam27
213550000003.240256 qam28
223630000003.740256 qam29
1Locked40.340741619
2Locked38.989859544
3Locked38.992788518
4Locked38.994468276
5Locked38.990837601
6Locked38.990977591
7Locked38.9100867505
8Locked38.999616436
9Locked40.3102816113
10Locked38.997966607
11Locked40.386036141
12Locked38.977285836
13Locked40.368795467
14Locked38.961665381
15Locked40.357714942
16Locked38.952154728
17Locked40.347754054
18Locked40.946073453
19Locked40.344363203
20Locked40.944522566
21Locked40.344062577
22Locked40.343632830
23Locked40.344982037
24Locked40.342951940
  • 65
Message 8 of 10
after 3 hours
32110000000.738256 qam10
42190000000.738256 qam11
52270000000.738256 qam12
72430000000.438256 qam14
132910000001.240256 qam20
142990000001.738256 qam21
163150000002.238256 qam23
183310000002.940256 qam25
19339000000340256 qam26
233710000003.540256 qam30
1Locked40.3228434465
2Locked38.913239383475
3Locked38.913094576959
4Locked38.613100275274
5Locked38.913171470007
6Locked38.913289869029
7Locked38.913187769961
8Locked38.912572660776
9Locked40.312294157359
10Locked38.911881754577
11Locked40.311155047341
12Locked38.910553342174
13Locked40.39770432481
14Locked38.98962824223
15Locked40.38531320804
16Locked38.97918217331
17Locked40.37034213889
18Locked40.36760712166
19Locked40.35963510489
20Locked40.3546978794
21Locked40.3539408587
22Locked40.3455388210
23Locked40.3340195860
24Locked40.3308875304
  • 65
Message 9 of 10
Today's numbers
22030000000.538256 qam9
42190000000.538256 qam11
62350000000.538256 qam13
72430000000.238256 qam14
82510000000.538256 qam15
122830000000.738256 qam19
173230000002.540256 qam24
183310000002.740256 qam25
19339000000338256 qam26
20347000000340256 qam27
213550000002.940256 qam28
1Locked40.319472824815
2Locked38.979238002415669
3Locked38.978496051747729
4Locked38.980693451467663
5Locked38.980543731226765
6Locked38.980513601248552
7Locked38.980354981256720
8Locked38.66785112821805
9Locked40.36672481676041
10Locked38.96238098575091
11Locked40.35213245420017
12Locked38.94510245349140
13Locked40.33275779231928
14Locked38.92568794174089
15Locked40.32201094144288
16Locked38.91676383103764
17Locked40.3121927174768
18Locked40.3100923255330
19Locked38.974511343670
20Locked40.361616436213
21Locked40.358565436112
22Locked40.348039734833
23Locked40.335088131073
24Locked40.329131827491
  • 12.3K
  • 952
  • 1.58K
Message 10 of 10
Can you switch the Hub off using the small switch then unplug the PSU.
Then ...
Go round ALL the VM co-ax cables, including V6 / Vito boxes, if you want disconnect and reconnect and make sure they are good finger tight.
Then ...
Plug back in and switch on and leave it 5 minutes after reboot and repost the second table of the Downstream data.
Mike Robinson
