stroodle
Message 1 of 5
constant dropouts for months
Hi, another post with a similar problem. The first half year or so with M100 fibre was great, but there have been frequent dropouts in the past few months. This ranges from once a day, to multiple times an hour. Normally it's for about half a minute but regularly for much longer.
Here's a BQM I only just set up, and the usual requested router details following. Thanks in advance for any help!
BQM
stroodle
Message 2 of 5
Re: constant dropouts for months
1290750000938256 qam20
21387500005.938256 qam1
3146750000638256 qam2
4154750000638256 qam3
5162750000640256 qam4
61707500006.338256 qam5
71787500006.438256 qam6
81867500006.838256 qam7
91947500006.840256 qam8
10202750000740256 qam9
112107500007.138256 qam10
122187500007.538256 qam11
132267500007.538256 qam12
142347500007.940256 qam13
15242750000838256 qam14
162507500008.338256 qam15
172587500008.438256 qam16
182667500008.538256 qam17
192747500008.638256 qam18
202827500008.938256 qam19
212987500009.138256 qam21
223067500009.138256 qam22
233147500009.338256 qam23
243227500009.438256 qam24
1Locked38.6130538620
2Locked38.6297030
3Locked38.6260770
4Locked38.9346030
5Locked40.3579320
6Locked38.91020090
7Locked38.91620240
8Locked38.92237430
9Locked40.33320990
10Locked40.35138550
11Locked38.69325970
12Locked38.612523750
13Locked38.917580450
14Locked40.324325490
15Locked38.933260590
16Locked38.944921620
17Locked38.661059440
18Locked38.678896520
19Locked38.995179050
20Locked38.697406480
21Locked38.9152102140
22Locked38.9154212430
23Locked38.9161551490
24Locked38.6168196280
stroodle
Message 3 of 5
13940015750.5512064 qam9
24620009451512064 qam8
35370001051512064 qam7
46030000051512064 qam6
1ATDMA0060
3ATDMA0010
4ATDMA0030
stroodle
Message 4 of 5
30/01/2021 02:40:30ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
28/01/2021 13:49:51criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/01/2021 02:40:30ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/01/2021 07:29:11criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
19/01/2021 14:40:30ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/01/2021 05:33:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/01/2021 02:40:29ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/01/2021 08:56:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/01/2021 22:02:44ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:37criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/01/2021 00:04:25noticeSW download Successful - Via NMS
11/01/2021 00:00:56noticeSW Download INIT - Via NMS
07/01/2021 20:05:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/01/2021 19:55:11ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/01/2021 17:26:27criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
24/12/2020 19:55:10ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 12:06:41criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 07:55:10ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/12/2020 01:36:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
17/12/2020 19:55:9ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 20.76K
  • 2.21K
  • 3.68K
Message 5 of 5
Will need time for the BQM to build up. All your power levels are on the high side although still in range. The RS error couts are odd - very high Pre but 0 Post ? Not sure if this adds up to a connection issue. Are you getting disconnects on ethernet connections as well as wireless? If so they will show on the BQM. If not it may well just be wifi interference.
While waiting for the BQM - can you do this to get a blank sheet.
__________________________________
First switch the Hub off for 5 minutes AND unplug it from the mains. Whilst it's off, do a quick check that all of your coax cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling and wall box. Then switch it on again and leave 5 minutes
Then do a Hub “pinhole reset” - make sure the 2 passwords on the Hub sticker are still there and legible first ! Disconnect any ethernet cables from the Hub, and then with the Hub still "switched on" throughout, press pin in firmly with paper clip/SIM tray tool or similar "thin thing" and hold it firmly for at least 60 seconds, release the pin, leave for 10’ to stabilise - dont manually switch it off at any time.
When done, check back in the settings and ensure that the RS error counts have all reset to 0. Then check every hour or two for the next day or two to see if they start reappearing - they shouldn't.
