  • 17
andyl
broadband dropouts
I would appreciate it if someone could have a quick look at my router stats and possibly help me pinpoint the root cause of the problem I keep getting.   I was looking at the stats below just prior to my broadband and wifi dropping out ( My broadband and or wifi sometimes drop several times a day with the router then rebooting itself or me having to disconnect/reconnect .)
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
635000000
0.5
40
256 qam
25
2
459000000
-1.5
38
256 qam
7
3
467000000
-0.9
38
256 qam
8
4
475000000
-1.4
38
256 qam
9
5
483000000
-1.9
38
256 qam
10
6
491000000
-1.4
38
256 qam
11
7
499000000
-1.7
38
256 qam
12
8
507000000
-1
38
256 qam
13
9
515000000
-0.7
38
256 qam
14
10
523000000
-1.5
38
256 qam
15
11
531000000
-1.4
38
256 qam
16
12
539000000
-1.4
38
256 qam
17
13
547000000
-1.4
38
256 qam
18
14
555000000
-1
38
256 qam
19
15
563000000
-1
38
256 qam
20
16
571000000
-1
38
256 qam
21
17
579000000
-0.2
38
256 qam
22
18
587000000
0.2
40
256 qam
23
19
595000000
-0.4
38
256 qam
24
20
643000000
0
40
256 qam
26
21
651000000
0.2
38
256 qam
27
22
659000000
0.5
38
256 qam
28
23
667000000
0
38
256 qam
29
24
675000000
0.7
38
256 qam
30
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
40.9
131
902
2
Locked
38.6
78
213
3
Locked
38.6
62
178
4
Locked
38.6
80
174
5
Locked
38.9
60
147
6
Locked
38.9
59
149
7
Locked
38.6
66
171
8
Locked
38.9
71
253
9
Locked
38.6
67
322
10
Locked
38.6
70
183
11
Locked
38.6
60
258
12
Locked
38.6
69
153
13
Locked
38.9
62
305
14
Locked
38.9
79
359
15
Locked
38.9
60
259
16
Locked
38.6
65
217
17
Locked
38.9
78
349
18
Locked
40.9
71
393
19
Locked
38.9
65
312
20
Locked
40.3
59
310
21
Locked
38.9
57
388
22
Locked
38.9
51
238
23
Locked
38.9
60
396
24
Locked
38.9
68
411
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
32599725
4.05
5120
32 qam
3
2
25800097
3.975
5120
16 qam
4
3
39400085
4.15
5120
32 qam
2
4
46200043
4.65
5120
64 qam
1
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
ATDMA
0
0
0
0
2
ATDMA
0
0
0
0
3
ATDMA
0
0
0
0
4
ATDMA
0
0
0
0
Time
Priority
Description
21/07/2019 12:40:20
critical
21/07/2019 12:41:15
critical
Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2019 12:41:15
critical
21/07/2019 12:41:52
critical
21/07/2019 12:41:52
critical
21/07/2019 12:42:30
critical
21/07/2019 12:42:30
critical
21/07/2019 13:47:20
critical
Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2019 13:47:20
critical
Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2019 13:47:20
critical
21/07/2019 13:47:51
critical
21/07/2019 13:47:51
critical
21/07/2019 13:49:33
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
21/07/2019 13:50:14
critical
21/07/2019 18:02:17
critical
21/07/2019 18:03:9
critical
21/07/2019 19:48:25
critical
01/01/1970 00:01:38
critical
22/07/2019 10:38:10
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/07/2019 10:38:18
critical
  • 1.04K
  • 42
  • 74
Re: broadband dropouts
Hello Andyl, thank you for your post and sorry you're experiencing some broadband issues.
Can I please just confirm a few things in regard to the broadband.
Is this happening through both wired and wireless devices?
If so, are the tests shown on a wired or wireless device?
Please let us know so we can investigate further.
Thank you, Emily.
  • 11.8K
  • 1.08K
  • 2.56K
griffin
The logs are showing the Docsis connection dropping between the Hub and the CMTS.which needs investigating by VM.
Unfortunately, this does not mean you have wireless issues as well.
  • 9
englishbloke
I have exactly the same issues. Quickly looking at the forum, it seems to be a very common problem. After calling support the other week, it was diagnosed as an intermittent problem with the Hub and sent out new equipment. Funnily enough, I still have the same problem!
 Are VM going to admit that there is an issue?
  • 6.59K
  • 511
  • 1.1K
Legend
Your circuit should not have that mix of 64/16/32 QAM on the upstream channels, they should all be 64 QAM. I suspect noise ingress on those frequencies. Only a technician’s visit can fix this.
@englishbloke, symptoms may appear again, but often the problems are not the same. If you wish help on the board, please raise a separate post.  It gets very confusing for people to respond when there are two or more people saying they have the same problem.
  • 17
andyl
Emily thanks for your comments.  At the moment I have a phone , V6 box and Laptop all connected via wifi.  However this problem has been ongoing for about ten years, and I get the same issues even when connected directly via a cable.  Some further background, I had an engineer(one of many over the years) call on ( 2/7/2019) and he confirmed that I had noise on the line which he identified as coming from a loose connection on a splitter to be the cause -  I suspected this was just an excuse to get to his next job ASAP, and as I suspected the problem reoccurred within a day.  I then rang the help desk again when the operator tried to fob me off by telling me to reboot the router - I do this almost daily - sometime several times a day.  I refused the offer of another engineer - and instead asked for a complaint to be raised.  After a further week of issues, I called again on 11/8/2019, only to be told that my complaint had not been actioned but simply closed. The operator then raised a further complaint, and I received a call yesterday evening.  The person I chatted to agreed there was no point sending another engineer and they would instead monitor my line for a couple of weeks.  Regarding "Tuder's" comment  "Your circuit should not have that mix of 64/16/32 QAM on the upstream channels, they should all be 64 QAM"   The engineer shrugged his shoulders and ignored this point when mentioned and the Complaint Handler dismissed it as irrelevant and just an example of a superuser demonstrating he knows a little bit more than most ....
Anyway I will wait a couple of weeks, but I have zero confidence that Virgin have the ability or incentive to resolve my issue and I will probably move to another supplier as my patience has just about run out.
Andy
