foreverangelic
  • 12
best way to enable consistant wifi /no lagging
Hi all,
Apologies in advance any type of technology throws me, but in my sons bedroom he constantly loses connection to wifi or gaming is always lagging, we have wifi boosters which are not effectively overcoming this problem, whats the best way around sorting this problem?
thanks in advance
  • 20.7K
  • 2.2K
  • 3.66K
Re: best way to enable consistant wifi /no lagging
There are lots of options - but first - any serious internet gamer would connect by ethernet cable. Is that possible - can you easily run a cable from the Hub to your son's bedroom?
What is the wifi like in the rest of your property? Do you have anything connected on ethernet cable - if so - how do they perform.
foreverangelic
  • 12
Hi John
Thanks for your reply and apologies for delay in responding
The hub is downs stairs and sons bedroom is upstairs on the opposite side of the house, it would probably be possible to do this for him.  My other son has the same problem also , though but his bedroom is at the back of the house (so not so easy to run/disguise wires)  As far as i know my husband has used ethernet cable from the boosters in their rooms to the x boxes.
Only other thing connected on ethernet cable is the TV. WIFI runs good in the living room but temperamental in kitchen/diner.
Vanessa
