ians44
Message 1 of 5
adding Netgear WiFi access point
Need to install VM supplied Netgear Powerline 500 Wifi Access Point XWNB5201.  Had them on previous system with Tivo but need to boost diabolical Wifi in part of house.
gary_dexter
  • 29.02K
  • 1.78K
  • 3.79K
Message 2 of 5
Re: adding Netgear WiFi access point
Plug it in?
what’s the question exactly?
ians44
Message 3 of 5
Basically, I have a set of WiFi extenders supplied by VM several years ago before I had a Hub3 installed in study on first floor.  The WiFi around the ground floor varies from great in room below study to very varied elsewhere, anything from below 5mps to 50+mps.
The extenders are Netgear Powerline 500 wifi extender and base connected by ethernet to Hub. I don't know how to set them up so they have the same ID as the hub, ie VM1234567.  I don't want to keep swapping access nodes.  I thought they should just boost the WiFi on ground-floor from the Hub3.  Any suggestions, bearing in mind that I am a bit of a technophobe.
Ian
gary_dexter
  • 29.02K
  • 1.78K
  • 3.79K
Message 4 of 5
They're old kit now and probably not that good.
I would look into getting something more up to date like a decent mesh system
tehwolf
  • 1.58K
  • 257
  • 384
Superfast
Message 5 of 5
Ian
You will need to log into teh netgear devices and change the SSID name to match that of your hub.. instructions for doing so are here - page 10 onwards.
