  • 21
Message 1 of 5
accessing ethernet hard drive via hub4.0
I seem to be having problems with accessing my Western Digital MyCloud ethernet hard drive connected to hub 4 using windows explorer LAN on windows10 ... and to top it all I have reset to the factory settings/default username/password on the base andeg attached I cant access the hub at all now.. IVE GOT the www. Early symptoms jpg attached!:
  • 11.31K
  • 887
  • 1.44K
Message 2 of 5
Re: accessing ethernet hard drive via hub4.0
On my WD drive it needs to be connected through a >> Switch <<, it won't work through the Hub.
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 11.31K
  • 887
  • 1.44K
Message 3 of 5
A simple switch setup ...
WD-LAN-Drive
Mike Robinson
  • 21
Message 4 of 5
It worked with Hub3.0. Set factory reset press at back and I cannot access http://192.168.0.1 portal with the default password at base of hub
  • 2.2K
  • 143
  • 428
Problem sorter
Message 5 of 5
Agree with Mike, any local network devices should be connected via a switch.  It's better practice to have your local LAN traffic on the switch, than having to go via your Hub 3.
