Yet another internet problem
Ceejay2021
Another day, another internet problem it seems. I only had an engineer out in July!  A new cable and exchange box was installed then. I'm finding the number of issues unacceptable.
Our internet has been playing up for the past three days. Intermittently cutting out and the light on the hub flashing.
The issues particularly seem to happen whenever there has been rain.
14 REPLIES 14
Can you do this... check for any “known network faults in your location - Look in 2 places
1) Try the “check service,”Area status webpage (https://www.virginmedia.com/help/service-status)
2) Then also Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
Then
Post up your Hub/network connection details and someone will check to see if there is a problem there.  In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
Ceejay2021
Thanks for the reply. I have called and check the website for known issues and neither are saying there are any area issues.
Downstream data:
323870000001.59999840.366287QAM25632
41630000006.00000040.366287QAM2564
51710000005.80000338.983261QAM2565
61790000005.69999738.983261QAM2566
71870000005.59999838.983261QAM2567
81950000005.50000040.366287QAM2568
92030000005.30000338.983261QAM2569
102110000005.40000240.366287QAM25610
112190000005.40000240.366287QAM25611
122270000005.30000340.946209QAM25612
132350000005.19999740.366287QAM25613
142430000005.09999840.946209QAM25614
152510000005.09999840.366287QAM25615
162590000004.59999840.946209QAM25616
172670000004.19999740.366287QAM25617
182750000004.09999838.983261QAM25618
192830000004.30000340.366287QAM25619
202910000004.40000238.605377QAM25620
212990000004.59999840.366287QAM25621
223070000003.90000238.983261QAM25622
233150000003.20000138.983261QAM25623
243230000001.40000237.636276QAM25624
25331000000-1.09999838.605377QAM25625
26339000000-0.50000038.605377QAM25626
273470000000.40000238.605377QAM25627
283550000000.70000138.605377QAM25628
293630000001.29999938.983261QAM25629
303710000001.59999838.983261QAM25630
313790000001.70000138.983261QAM25631
333950000001.40000238.983261QAM25633
344030000001.29999940.366287QAM25634
3.0 Downstream channels
32Locked40.36628700
4Locked40.36628700
5Locked38.98326100
6Locked38.98326100
7Locked38.98326100
8Locked40.36628700
9Locked38.98326100
10Locked40.36628700
11Locked40.36628700
12Locked40.94620900
13Locked40.36628700
14Locked40.94620900
15Locked40.36628700
16Locked40.94620900
17Locked40.36628700
18Locked38.98326100
19Locked40.36628700
20Locked38.60537700
21Locked40.36628700
22Locked38.98326100
23Locked38.98326100
24Locked37.63627600
25Locked38.60537700
26Locked38.60537700
27Locked38.60537700
28Locked38.60537700
29Locked38.98326100
30Locked38.98326100
31Locked38.98326100
33Locked38.98326100
34Locked40.36628700
159964K1840QAM4096424
159Locked422.7184105193147180
Ceejay2021
Welcome back!
Sign in to view or modify your Hub 4 settings.
PasswordShow
Router status
3.0 Upstream channels
13660000036.0205995120 KSym/sec64QAM3
22360000035.2705995120 KSym/sec64QAM5
33010000036.0205995120 KSym/sec64QAM4
44310000036.5205995120 KSym/sec64QAM2
54960000037.0205995120 KSym/sec64QAM1
1US_TYPE_ATDMA0000
2US_TYPE_ATDMA0000
3US_TYPE_ATDMA0000
4US_TYPE_ATDMA0000
5US_TYPE_ATDMA0000
3.1 Upstream channels
610.031.22KQAM8
6OFDMA20053.9190
Ceejay2021
Welcome back!
PasswordShow
Router status
Mon Oct
6US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: .;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Oct
5DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Oct
6US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Oct
Mon Oct
Mon Oct
3No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Oct
Mon Oct
Mon Oct
Mon Oct
Mon Oct
4DBC-ACK not received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Oct
Mon Oct
Mon Oct
Mon Oct
Mon Oct
Mon Oct
Mon Oct
Mon Oct
Mon Oct
Mon Oct
Mon Oct
Mon Oct
Mon Oct
6DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Oct
4DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Oct
4DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Oct
Mon Oct
Mon Oct
Mon Oct
Mon Oct
Mon Oct
Mon Oct
Mon Oct
Mon Oct
Mon Oct
Mon Oct
Mon Oct
6CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon Oct
Mon Oct
Mon Oct
Mon Oct
Mon Oct
Mon Oct
Mon Oct
Mon Oct
Mon Oct
Sun Oct
Sun Oct
Sun Oct
Post the downstream data and BQM Link.  Copy and paste the text.
81950000005.50000038.983261QAM2568
102110000005.19999740.366287QAM25610
112190000005.40000240.946209QAM25611
122270000005.30000340.366287QAM25612
142430000005.19999740.366287QAM25614
162590000004.69999740.366287QAM25616
172670000004.09999840.366287QAM25617
202910000004.19999738.605377QAM25620
212990000004.30000340.366287QAM25621
223070000003.50000038.983261QAM25622
233150000002.79999938.983261QAM25623
243230000002.29999938.983261QAM25624
253310000001.79999938.983261QAM25625
263390000001.59999838.983261QAM25626
273470000001.40000238.983261QAM25627
283550000001.09999838.983261QAM25628
293630000001.40000238.983261QAM25629
303710000001.59999838.605377QAM25630
313790000001.59999838.983261QAM25631
333950000001.50000038.983261QAM25633
344030000001.50000040.366287QAM25634
32Locked40.36628700
4Locked40.36628700
5Locked38.98326100
6Locked38.98326100
7Locked38.98326100
8Locked38.98326100
9Locked38.98326100
10Locked40.36628700
11Locked40.94620900
12Locked40.36628700
13Locked40.36628700
14Locked40.36628700
15Locked40.36628700
16Locked40.36628700
17Locked40.36628700
18Locked38.98326100
19Locked40.36628700
20Locked38.60537700
21Locked40.36628700
22Locked38.98326100
23Locked38.98326100
24Locked38.98326100
25Locked38.98326100
26Locked38.98326100
27Locked38.98326100
28Locked38.98326100
29Locked38.98326100
30Locked38.60537700
31Locked38.98326100
33Locked38.98326100
34Locked40.36628700
3.1 Downstream channels
159Locked422.91267844094147612
BQM ?
Ceejay2021
I haven't been able to set up a BQM as I don't have a computer at home.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/a7d8e9af1252d2048993be09dddbf10641ec9f85-03-10-2023
