on 12-04-2023 10:19
Connected in November, never had a white light which the manual states is white when working correctly. Therefore argument with virgin it has never "worked properly" wifi drops in/out occasionally.
Virgin run tests and clear down fault when they haven't actually cured the fault.
There have been "complex" issues in my area causing over 20 customers to have problems, been going on for months too.
Are the problems connected?
Suggestions to help please?
I have reset and rebooted many times.
Answered! Go to Answer
on 12-04-2023 15:59
on 12-04-2023 15:59
on 12-04-2023 16:07
Thank you John
We joined virgin in Nov 2023 and had kit sent to us, I'll check with virgin to see if it was a refurb or new hub 3.
Will also try to log outages, but with a complex problem noted in the area, it may be linked.
on 12-04-2023 16:15
on 14-04-2023 16:41
Hi JollyJack8,
Thanks for your post and welcome to the Forums. It's great having you on board with us in the Community 🤩
We're sorry to hear about the issues you have been having with your connection. Checking our systems, I can see that there is a fault open that is affecting you. The details of that are here:
The teams have already made a note of this on your account so they are aware you are affected and this will ensure the account is assessed automatically for automatic compensation once the fault is closed as resolved.
Just as a further note, the fault is an SNR fault - SNR (signal to noise ratio). This is just a technical term for interference of the Broadband signal caused by noise which ingresses on to our network. It's a difficult problem to locate and diagnose. This is because noise can ingress anywhere on our network. As a general rule it's normally caused by customer equipment e.g. loose connections or 3rd party equipment attached to our network. However it can also be attributable to local architecture, e.g street cabinets, cabling or at the origin of the signal which we call the Headend (servers/routing system). The only way to establish where the noise is originating is for the Network Techs to run a series of trace routes. Once found then the cause dictates the amount of work required and the time frame for resolution.
If there is anything else we can do, let us know.
