jayman-123
  • 26
Message 1 of 1
Yellow light on hub 3
Hello, My virgin hub 3 has a yellow light and speed is good but the quality is not.
When playing online games on my PC which is connect to modem directly via ethernet, I get intermitted desync and steaming games over the internet is another story, it works fine at first but like 5-10 minutes later, you can notice that the game graphic are getting slower until it fails due to poor internet quality, get similar problem on other devices which are via Wi-Fi as well.
if you are using the internet for watching on demand or downloading stuff, do not notice a issue.
I tried rebooting and pressing in the reset to factory setting and checked all connect are tight.
any idea???
